Apparently; firmware upgrades are not automatic and regular maintenance has been ignored on two QNAP devices.
Both systems are: Model:TS-421 Current firmware version:4.3.3.2057 Date:2022/06/23
I notice Status = A new firmware version is available. Click “Check for update” to update.
I click “Check for update”; 4.3.3.2784 Build 20240619 is available for download.
On first system; click “OK” and upgrade is installed without issue.
On the second system with same “current firmware” as above; I click “Check for update”.
Downloading firmware proceeds from 0% to 100%; no issue.
Then “Updating system” Upgrade proceeds to 30% then I get:
Failed to update system. The firmware file format is abnormal. Error Code: 4.
What is my next step?
