HDD tray key for TS-439 Pro II+
I’m looking where can I find key for my TS-439 PRO II+
And if you have the exact name for this key, will appreciate.
On QNAP site it is write : Hard disk lock x 1
on https://eustore.qnap.com/ it’s such models :
KEY-01, KEY-02, KEY-03, KEY-HDDTRAY-01
but none of these articles specify which QNAP model they are intended for
Thank’s in advance for your help
Karel
Hi and welcome to the forum. :slight_smile:
Many QNAP models from that time used the same barrel key because the drive trays were all identical. It’s the same key for my TS-559 Pro+ and TS-569 Pro.
Try this one: https://store.qnap.com/key-hddtray-01.html
Or, the free alternative: Quick Fix: Lost QNAP Key for Hard Drive Tray
I also found this FAQ
It seems that there are only two types, plastic and metal key
Thanks,
But the Qnap shop propose 3 models for metal
And we can’t find on the Qnap documentation for which model of NAS it concern :cry:
The US QNAP store shows only two types: metal and plastic. https://store.qnap.com/accessories/accessory/key.html
I don’t know why the shop has several part codes for the same item. If it was eBay or AliExpress, different codes would mean different styles, colours or quantities. The only similarity here is the quantities. All the metal keys are the same.
Best to ask QNAP directly. Create a support ticket: QNAP Account Center
Thank you for the informations (appreciate).
I’ll look forward to buy the model KEY-HDDTRAY-01.
Actually, this is for a friend whose QNAP was hit a few years ago by the eCh0raix ransomware (new version).
We waited to see if a solution—other than paying the ransom—would become available.
But nothing until now.
So, I’m going to take out a drive to make a backup using Clonezilla, for example, before formatting it. Just in case a solution to decrypt it becomes available.
Regards
The two metal keys above are likely the same. Look at the part numbers - KEY-03-10PCS - that’s a 10 piece pack of keys.
