Hi everyone,
I have two QNAP NAS units at different sites, on different ISPs and routers. I’ve been using QuWAN Express via the free Super Node service to run scheduled backups between them. It worked reliably until about two weeks ago, then stopped on both units at the same time. I haven’t changed anything in my setup.
Setup
- NAS 1 (remote): [TS-451+]
- NAS 2 (home): [TS-932X]
- Both are signed in with the same QNAP ID and are in the same QuWAN organization
- Location: Australia, NBN. I suspect both connections are behind CGNAT.
Symptoms
- QuWAN Express shows “Disconnected” and says it is not connected to a hub
- QuWAN Orchestrator also shows both devices as disconnected
What I’ve already tried
- Signed out and back in to my QNAP ID
- Updated QVPN Service and the QuWAN apps (and firmware)
- Left QuWAN Express and rejoined
- Confirmed the L2TP/IPSec server is disabled by default
- Checked the NAS time (NTP sync)
Questions
- Is there a known issue or outage with the QuWAN Express Super Node service in the Asia-Pacific/Australia region?
- Has QuWAN Express changed recently, for example in its CGNAT support, free-tier eligibility, or hub/region availability?
- Is there a log on the NAS that shows why the connection to the Super Node fails? Where do I find it?
- Which ports do I need open outbound for it to work (UDP 500, 4500, 7788, 5555 and 61001-62000)? Is there a way to test them from the NAS?
Thanks in advance!
