How to monitor the temperature of a QNAP QXG-10G1T 10GbE network card via SSH
QTS displays several hardware temperatures in its Hardware Information panel, including CPU, system and hard drive temperatures.
However, it does not display the temperature of the additional network card.
I found a way to retrieve two additional temperature readings from my QNAP QXG-10G1T 10GbE PCIe network card using the Linux hardware monitoring interface (hwmon).
1. Connect to your NAS via SSH
Log in using an administrator account.
2. Retrieve the two network card temperatures
Run the following command:
for t in /sys/class/hwmon/hwmon2/temp{1,2}_input; do
label=$(cat "${t%_input}_label")
value=$(cat "$t")
awk -v l="$label" -v v="$value" 'BEGIN {printf "%s : %.1f °C\n", l, v/1000}'
done
3. Example output
PHY Temperature : 78.0 °C
MAC Temperature : 76.0 °C
These are two separate temperature readings:
PHY Temperature: temperature reported by the physical network interface circuitry.
MAC Temperature: temperature reported by the network controller’s MAC circuitry.
4. Improving the card’s cooling
I also replaced the original thermal paste, which was of rather poor quality, with Thermal Grizzly Kryonaut.
This resulted in an approximately 9°C reduction in operating temperature.
This is worth considering if your QXG-10G1T runs particularly hot. Make sure to check the thermal interface and heatsink contact before attempting any modification.
5. Important notes
These readings are not displayed in the standard QTS Hardware Information panel.
The temperatures are read directly from Linux
hwmonsensor files. -
The
hwmon2identifier may differ depending on your NAS model, hardware configuration and QTS version. Check/sys/class/hwmon/and the correspondingnamefiles if the command does not work. -
This method does not require installing additional software.
Tested configuration:
NAS: QNAP TVS-871
QTS: 5.2.11 (build 20261014)
Additional network card: QNAP QXG-10G1T
Thermal paste replacement: Thermal Grizzly Kryonaut
Observed temperature reduction: approximately 9°C
This is a useful way to monitor temperatures that QTS does not expose in its graphical interface.
