Login NAS TS-431PD no longer works after hard reset 10 seconds
I have tried as far as I know everything. Credentials admin admin don’t work
there is no TS-431PD
admin - admin work only for QTS 4.4 or earlier.
For other QTS versions
What is the default system administrator password for my NAS? | QNAP
Thank you to Becker2020 for the helpful explanation and reference link.
As mentioned in the FAQ shared by Becker2020, after a system reset the default admin account will be enabled again, and the default password depends on the QTS / QuTS hero version. For QTS / QuTS hero 5.2.0 and later, the default password is the device’s Cloud Key, entered in uppercase letters without special characters.
For example:
If the Cloud Key is Q1234-5678, please enter the password as Q12345678.
FAQ for reference:
Thank you.
