Network connections issues with my TS-453D
I have a TS-453D that has been having a lot of issues of late. Replaced a failing drive last week on my Raid 5 array and that seems to have resolved a lot of my issues, but I still seem to have a pretty major network issue with it. Current firmware is QTS 5.2.11.3661. When I go to Web Server in Control Panel I get a message that says “Note: To use this function, please upgrade the system firmware…”.
Any attempt to manually update the firmware fails with a “Failed to update system. A file check error occurred. Error code: 11”
After some googling, I was trying to update the DNS server information, but any attempt to get to the Network and Virtual Switch comes up with a big Error window that says Page not found or web server is currently unavailable.
I am sure there is something wrong somewhere and I am not competent enough with this system or networking in general to resolve it. Any help you could provide would be appreciated.
I would suggest to open a ticket with QNAP support. Seems like something is not quite right.
Since both the firmware update and the Network & Virtual Switch page are failing, we’d recommend opening a support ticket so our Support Team can take a closer look at your NAS.
QNAP Helpdesk
Thanks!
