Is there a way to solve qnap TS-832PX Raid5 pool converted to read only mode after full storage ?
it didnt work with me
What happened when you tried (and at what step) ?
these commands didnt recognised for my in putty
7. run the following command “storage_util –sys_startup”
- run the following command “storage_util –sys_startup_p2”
Make sure you run these as ‘admin’, re-enable admin if it’s disabled
[~] # storage_util –sys_startup
Try `storage_util --help’ for more information.
[~] # storage_util --help
Maybe open a ticket then, the guide could be outdated if the commands are not recognized (hence the request for a ‘help’ flag to list all modes)
Hi guys, I’ve just had a look at this. The syntax is correct, but the characters rendered on the old forum are misleading. Originally a copypaste error it seems. ![]()
It works if the correct characters are used.
Try this:
storage_util --sys_startup
Example (from a TS-251+ with QTS 5.2.7):
[~] # storage_util --sys_startup
Detect disk(8, 16)...
ignore non-root enclosure disk(8, 16).
Detect disk(252, 0)...
ignore non-root enclosure disk(252, 0).
Detect disk(8, 0)...
dev_count ++ = 0
… and:
storage_util --sys_startup_p2
Example:
[~] # storage_util --sys_startup_p2
sys_startup_p2:got called count = -1
Ok ,this is working .
i tried to run commands to delete and still (Read-only file system)
Hi, could you please provide a screenshot of your UI?
We would like to confirm if you are referring to Read/Delete? If so, you can also refer to this FAQ article: What does it mean when a volume status is “Read/Delete”, and what can I do? | QNAP
