QVR Client Web Beta is Now Open for Trial
camera only setup with one feed
@marcoi could share your web debug log with me? we can check the codec issue and the keep connecting issue together.
sure how can i send it to you securely? I dont want to post it on the forums
I think you can put it into a folder on NAS and create a smart URL then reply to me at the private message which I share the QVR Client Web Beta with you.
i want . +1
Can I participate please? Thanks
Hi would like to try the new beta thank you.
@haru0 I would also like to be added to the beta program!
I am a linux user and I was waiting for this since forever
Please add me as a tester, as well. Thanks.
I wish to give it a try.
Hi, I’m in the process of migrating from Windows to Linux (Fedora) and I’m in desperate need of usable all in one solution similar to QVR Pro/Surveillance windows app. Just upgraded my QNAP setup from QVR pro to QVR Surveillance and on Windows all works fine. I have just basic needs to be able to watch live 4 cameras + access and save recordings from those cameras, just like on Windows app. I’d really appreciate to be able to test your Web Client.
Please add me
Please add me!
Hi Please send me the link
