Specific initial setup help request
Hello! I’m Sam, and I’ve used other companies’ NAS devices in the past and recently expanded to a QNAP device (TS-873A). I’m trying to do some fairly specific things with my unit, and I’m hitting a bit of a wall.
From the ask of included information:
Windows
TS-873A
QTS 5.2.7.3256
1.) I’m trying to set up my NAS in part as a media server, accessible through Kodi via NFS/UPnP/SMB of whatever actually works. With pervious devices, I’ve used UPnP. If the QNAP requires opening ports or whatever… I’m gonna need some help on that. Treating me like I’m completely clueless would be greatly appreciated.
2.) My preference would be to have multiple volumes, with some as media servers and some as cloud data storage for work. It’d be nice to retire some of my other devices.
3.) With the previous devices, and Windows, I was able to link the device with Explorer to treat the NAS as just another drive. I thought I had done that with my TS on initial setup (via the QFinder app), but “lost” the connection when updating my NAS. Is that a normal issue, and if I set it up again it should remain stable, or is this something that will regularly occur with firmware updates and whatnot?
Thank you for your patience.
  1. Simple SMB and NFS setup is explained here
  2. No need for extra volumes, you can setup shares (no difference for users as all is accessed via shares)
  3. you can bind shares via gui or net use, very simple no need for any app
Regarding media servers, you might also want to look into Plex and Roon.
The Best NAS for Plex | QNAP
Roon on NAS | Building the ultimate music server | QNAP
I just update my TS-831X from v5.2.5 to v5.2.7. My map network drive looks fine. Only disconnect during NAS reboot and resume normal after NAS back.
