Backstory
- My QNAP TS-451A had hardware failure on bay 4. The drive in bay 4 became stale, but all drives (including 4) were operational.
- Unwilling to get a new QNAP
- While QNAP RAID originated with Linux, the LVM headers have been modified to the extent that stock Linux can not access them.
- Encrypted volume recovery is all but impossible.
Foreword
- I make no claims to be an expert in this area. Please feel free to suggest improvements.
- The below method will likely work for a number of other circumstances with minimal adjustments.
- The forum limited me to 2 links. Please find the rest via Google.
What is Needed - for this specific method.
- Remaining or all members of the QNAP RAID array
- Enough storage, on other drives, as target for RAID recovery
- Proxmox (ideally bare metal), with required number of drive bays
- Qnap QuTScloud subscription - start at $4.99 USD / Month
- Patience
General Procedure
Move Physical Drives
- Initial processing of drives removed from QNAP
- Get the model number and size of the drives from the physical sticker on the drive
- Taking a photo of each label can be helpful
- Install the QNAP drives into the Proxmox machine
From Proxmox: Get Drive Info
- install packages in Proxmox
apt install mdadm lvm2 thin-provisioning-tools- You may need more / less, this will get you started
- Find the QNAP drives
- Proxmox UI > Node drives are installed in (first column) > Disks (second column)
- Look for the model number of the drives you recorded earlier
- QNAP drives will generally have 5 partitions and partition usage will be ‘linux_raid_member’:
- Partition 1 & 2: Small partitions for QNAP OS/Config (RAID 1).
- Partition 3: This is usually your actual data (RAID 5).
- Partition 4 & 5: Swap and reserved space.
- These may be changed with other QNAP versions, the largest partition will almost certainly be the data partition.
- Find the Target Drives (where you will export the data to)
- Get additional information on drives. – I found these helpful
ls -al /dev/disk/by-idlsblklsblk -af -o NAME,SIZE,FSTYPE,TYPE,MOUNTPOINT,UUID,WWN,HCTL,TRAN,SUBSYSTEMSlsscsi -gfdisk -l
From Proxmox: Setup QuTScloud
- Determine which QuTScloud license key is appropriate
- QuTScloud
- Current pricing starts at: 1 core: 4.99 USD/mo
- You don’t have to get the license yet, but you need to know the core count to setup your Virtual Machine (VM)
- QuTScloud
- Create a QuTScloud VM in Proxmox
- Download QNAP QuTScloud
- Import the image (customize the command as required)
qm importdisk 101 /root/QuTScloud_c5.2.4.3041.qcow2 local-data-00- When creating the VM shell in Proxmox
- I had to use SeaBIOS (most docs say use UEFI)
- Set the machine to ‘q35’
- Set SCSI controller to
VirtIO SCSI Single - include a Network Device (virtio) as this will be needed to validate your license.
- From within the Proxmox UI, initialize QuTScloud:
- Select the QuTScloud VM
- click ‘Start’
- click ‘console’
- This will display the console, which after booting, will display the LAN IP, and login details.
- Using a browser, login to QuTScloud using the IP address and provided Username and Pswd (default is ‘admin’)
- Get a QuTScloud license key & enter into local QuTScloud.
From Proxmox Shell: Connect drives to QuTScloud
- In my case, one of my drives was degraded (TS-451A Bay Failure). If that is your case as well, only connect the non-degraded drives - this keeps QuTScloud from having to figure it out.
- From within Proxmox, use something like this to pass the drives to QuTScloud (for 3 drives or 4 drive RAID 5):
qm set 101 --scsi1 /dev/sde,backup=0qm set 101 --scsi2 /dev/sdf,backup=0qm set 101 --scsi3 /dev/sdg,backup=0- Be sure to match VM number (101 here) and device nodes (drive designators) with your actual system
- It is better to use persistent designators here (e.g. by-id)
- You can try to add the drives as read-only (ro=1).
- Setting to Read-Onlly was not successful when I tried due to QuTScloud requiring write access to update drive metadata
- IMPORTANT: Send the individual drives to QuTScloud, do not assemble the drives in Proxmox and send the RAID.
From QuTScloud: Determine QuTScloud RAID Setup path (GUI or Shell)
- Either the GUI or Shell may work for this, I used the shell as the GUI did not find the drives.
From QuTScloud GUI: Setup SSH access to QuTScloud
- Use the GUI to enable SSH access.
- Control Panel > Network & File Services
From QuTScloud Shell: Get Drive Info
- Check the drives – the following are helpful
sudo cat /proc/mdstatsudo qcli_storage -dsudo fdisk -l /dev/sdc /dev/sdd /dev/sdesudo lvs- QuTScloud shell specific
qcli_storage -d
From QuTScloud Shell: Assemble RAID
- Once you have all the device nodes, assemble the RAID with something like this:
sudo mdadm --assemble --force /dev/md1 /dev/sdc3 /dev/sdd3 /dev/sde3
From QuTScloud Shell: Create Mounting Point & Mount
sudo mkdir /mnt/recoverysudo vgchange -ay vg1(may be required here).sudo mount -t ext4 /dev/mapper/vgl-lvl /mnt/recovery- If this does not work, try the GUI: Storage & Snapshots > Recover > Scan and Import Storage Pool
From QuTScloud GUI: Check ‘Storage & Snapshots’
- Hopefully your volume will now be visible in the QNAP GUI > Storage Pools & Volumese
Notes
- QuTScloud will constantly complain about the size of the OS disk.
- This is because of the way it was created from the qcow2 image
- This was never an issue for me
- I was able to recover both unencrypted and encrypted volumes
- You do need a valid encryption key for encrypted volumes
- Do NOT attempt to rebuild the array before recovering the data. – Always: Recover > rebuild
Keywords
- storage pool recovery
- volume recovery
- encrypted volume recovery
- QNAP hardware recovery
