Apps Missing After TS-469 Pro Auto Resets
Hello all,
Last Friday, our TS-469 Pro did a soft reset on its own. After some research, I found out that this is a known bug, so I disabled the Reset Button for now.
But the main issue is that Transmission is now missing, as if it had been uninstalled. When I SSH and check the hidden .qpkg folder, I see the app is there. It needs Optware to run, so I try starting it but get an “Optware is disabled” error.
I saved the Optware and Transmission .qpkg files, so tried manually installing them first but the install would just hang. When trying through PuTTY it looks like the Optware install hangs where it’s trying to download the ipkg, because I assume the source no longer exists?
I know these apps and this setup is old and outdated, but it was working flawlessly for years and now suddenly it’s not. I will look into upgrading but for the time being wanted to see if there was anything I can do to get this back up and running quickly.
I checked the qpkg.conf file and don’t see Optware or Transmission listed there, although their folders are still there in /share/MD0_DATA/.qpkg.
The system volume and the default shares are still present ?
Yes everything is there and data is untouched. Just had to go and reconfigure some general settings like Time, Scheduled Scan Jobs and SMART disk checks.
Has the NAS received any updates lately?
Hi Nelson,
Not it has not, it hasn’t been updated in years.
I still don’t understand how it spontaneously reset itself but that’s another issue for another day.
How long has it been since you do a scheduled reboot, like, since when you don’t update it (or does it no longer receive updates?). As much as they say that the servers do not shut down, from time to time must be made scheduled restarts to see refresh of the continuous load they carry, it is recommended to keep the computer up-to-date (if it still receives updates), I would suggest you do that first before trying anything, if this is your case you don’t have time without updating it.
Greetings.
Check one of the following below to see if it fits your case:
Some apps suddenly disappearing from your QNAP can be due to several reasons. Here are the most common ones:
  1. Firmware or App Updates
    Sometimes, after updating the NAS firmware or apps, some apps may no longer be compatible or may be automatically uninstalled if they don’t meet the new requirements.
  2. File System Issues
    If there is file system corruption or hard drive errors, apps may not load properly or may even disappear from the menu.
  3. Disabled Third-Party Apps
    If you installed apps from external (unofficial) sources, they may be disabled after a reboot, update, or change to security settings.
  4. Insufficient Space
    When the system detects a lack of space, it may disable certain features or apps to maintain NAS stability.
  5. Permission or User Settings
    If user or privilege settings have changed, some apps may no longer be visible to certain users.
  6. Malware or Unauthorized Access
    In more severe cases, if the system has been compromised (such as with QSnatch or DeadBolt malware), some apps may disappear or become inaccessible.
I restart it only when I do firmware updates on our router, which can usually be several months apart. I have restarted it several times already and the apps are still missing.
All those reasons you listed don’t apply as far as I can tell, and the spontaneous reset was a factory bug. It has not happened since I disabled the reset button.
If anyone familiar can please help me code this back to a working state I’d really appreciate it. As mentioned, the apps are still there in MD0_DATA but disabled.
Did you check the qpkg.conf to see if these apps are disabled in it ?
I found a qpkg.conf in etc/default_config that does not have the apps listed there. Am I looking in the right location? Couldn’t seem to find qpkg.conf anywhere else.
Should be in
/etc/config/qpkg.conf
At least on CAT2 devices, not sure about older units
Yes you’re right, there’s one in there too. Does not contain Transmission or Optware.
Does the NAS keep backups where I can perhaps pull a previous copy from? Or add whatever is necessary to the current empty file?
See if there is config backup tar files in
share/MD0_DATA/.@backup_config
Yes indeed they are there! Going past where the issue started. Do I gunzip these and look for the conf?
Never unzipped tar on QNAP before…just try tar command or just do it externally
Ok I’ll give that a shot. Also not sure how I’d get in that directory externally, but I’ll look into it.
Anyway to just restore the whole system using one of those backups?
Here’s how to extract just the qpkg.conf file:
https://forum.qnap.com/viewtopic.php?p=643513#p643513
You’re a legend, thank you!!! That worked!
All the apps are back and showing in the App Store. I took a backup of the .conf and the backup tars, just in case.
Thanks to @dolbyman and Nelson @office1 for the help and getting me pointed in the right direction :slight_smile:
