Configuring immutability or Read Only for a specific period on a Volume?
Would it be possible to configure an Immutability or Specific Read Only LUN with the QTS on a TVS NAS?
WORM is only available on shared folders with QuTS and QES
Thank you for the confirmation.
So in this case the TVS unit running QTS OS won’t be able to do WORM?
No, QTS does not support it
Although, QTS does support iSCSI ACLs, which might be enough: iSCSI Access Control List | QTS 5.0.x
Thank you, @dolbyman and @OneCD for your help.
