Conflicts between QuTS Hero and QTS
EXT4 and ZFS are PARTITION formats, NOT disk formats (if only a single partition is on a disk, I guess you could call it a disk format, but actually a misnomer). EXT4 and ZFS partitions can exist on the same physical disk; just need to use the appropriate command set for which filesystem you/QNAPinternals are manipulating.
If you’re on Hero, look at all the partitions on a disk that’s in use as part of a data pool. The data pool partition will be ZFS, but tell me which filesystem(s) you see on the other ‘hidden’ partition(s)…
Other than a possible disagreement with Dolbyman about whether a firmware image is in fact on DOM as shipped and updated during fimware updates, I agree with everything Dolbyman has told you is accurate and valuable info, as well as the alternate path I have provided to cleanly go from QTS to hero or back.
The steps you are trying don’t follow what QNAP doc nor Dolbyman nor I have described and you are confused/upset that an undocumented course of action is giving unexpected results. We’ve tried to explain where you went off course and each given you different documented alternatives on how to swap hero to qts or back. Perhaps if studying our responses aren’t ‘coming thru’ for you, maybe open a ticket and QNAP support’s explanation may be clearer. Maybe point to this thread on the ticket as supposedly QNAP support can and will look at this new ‘much unloved’ version of the forum.
Excuse my ignorance but how do you tell which filesystems are in use…
For a quick summary, enter this in your NAS shell:
df -T
Or, to see the fs type on every block device:
parted -l
Thanks! Yeah, lots of different file systems. See some EXT2, EXT3 and EXT4 partitions as well as the ZFS ones.
FYI - parted -l resulted in no output.
As you’re not logged-in to your shell as ‘admin’, you’ll need to prefix the command with sudo like:
sudo parted -l
Ah. Usually a command that requires sudo yells back at you. On a QNAP you can’t ping another IP w/o using sudo!
