Container Station TS469Pro
Hi
I am trying to find a solution to using Home Assistant on my TS460pro. I have pointed in the direction to using a container which i can’t seem to find for my model. Any help would be appreciated
I ended up running HA in a VM vs container. I have servers so running it as a VM was easy. i think you can do the same using Virtualization Station on your qnap.
HA VM install
That link kind of walks you through the steps. In Virt Station you can try to setup the downloaded file and import it into VS.
I havent done this before so you may be doing some trial and error. Hopefully it works out.
I guess you mean TS-469 Pro? (The one you gave does not exist)
That NAS is by far too old for ContainerStation, it’s from 2012
