Container Station - Ubuntu System Volume Device - Disturbing Findings
I am trying to do something in a Linux container but I am having some difficulty and finding some surprising results.
I’m trying to identify the device in /dev that is the system volume for the installation. However, when running a command like lsblk I literally see every volume on the NAS!
First of all, I thought a container install was supposed to be “isolated” from the rest of the NAS. It isn’t. It seems like you can’t access the container from the NAS, but dang you sure have access from the container to the rest of the NAS. This is pretty disturbing.
Second, no mount point of / is ever listed.
root@45217fe699b0:/# lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINTS
loop0         7:0    0    64M  1 loop
sda           8:0    0   1.8T  0 disk
|-sda1        8:1    0 517.7M  0 part
| `-md9       9:9    0 517.6M  0 raid1
|-sda2        8:2    0 517.7M  0 part
|-sda3        8:3    0   1.8T  0 part
|-sda4        8:4    0 526.6M  0 part
| `-md13      9:13   0 448.1M  0 raid1
`-sda5        8:5    0  31.5G  0 part
  `-md322     9:322  0  30.4G  0 raid1 [SWAP]
sdb           8:16   0   1.8T  0 disk
|-sdb1        8:17   0 517.7M  0 part
|-sdb2        8:18   0 517.7M  0 part
|-sdb3        8:19   0   1.8T  0 part
|-sdb4        8:20   0 526.6M  0 part
`-sdb5        8:21   0  31.5G  0 part
sdc           8:32   0   9.1T  0 disk
|-sdc1        8:33   0 517.7M  0 part
|-sdc2        8:34   0 517.7M  0 part
|-sdc3        8:35   0   9.1T  0 part
|-sdc4        8:36   0 526.8M  0 part
`-sdc5        8:37   0  31.5G  0 part
sdd           8:48   0   9.1T  0 disk
|-sdd1        8:49   0 517.7M  0 part
|-sdd2        8:50   0 517.7M  0 part
|-sdd3        8:51   0   9.1T  0 part
|-sdd4        8:52   0 526.8M  0 part
`-sdd5        8:53   0  31.5G  0 part
sde           8:64   0   9.1T  0 disk
|-sde1        8:65   0 517.7M  0 part
|-sde2        8:66   0 517.7M  0 part
|-sde3        8:67   0   9.1T  0 part
|-sde4        8:68   0 526.8M  0 part
`-sde5        8:69   0  31.5G  0 part
sdf           8:80   0   9.1T  0 disk
|-sdf1        8:81   0 517.7M  0 part
|-sdf2        8:82   0 517.7M  0 part
|-sdf3        8:83   0   9.1T  0 part
|-sdf4        8:84   0 526.8M  0 part
`-sdf5        8:85   0  31.5G  0 part
sdg           8:96   1   1.8T  0 disk
|-sdg1        8:97   1 517.7M  0 part
|-sdg2        8:98   1 517.7M  0 part
|-sdg3        8:99   1   1.8T  0 part
|-sdg4        8:100  1 526.6M  0 part
`-sdg5        8:101  1  31.5G  0 part
sdh           8:112  1 931.5G  0 disk
|-sdh1        8:113  1 517.7M  0 part
|-sdh2        8:114  1 517.7M  0 part
|-sdh3        8:115  1   898G  0 part
|-sdh4        8:116  1 526.2M  0 part
`-sdh5        8:117  1  31.5G  0 part
sdi           8:128  0 372.6G  0 disk
|-sdi1        8:129  0   200M  0 part
`-sdi2        8:130  0 372.3G  0 part
sdj           8:144  1   4.6G  0 disk
|-sdj1        8:145  1   5.1M  0 part
|-sdj2        8:146  1 488.4M  0 part
|-sdj3        8:147  1 488.4M  0 part
|-sdj4        8:148  1     1K  0 part
|-sdj5        8:149  1   8.1M  0 part
|-sdj6        8:150  1   8.5M  0 part
`-sdj7        8:151  1   2.7G  0 part
sdk           8:160  0  10.9T  0 disk
`-sdk1        8:161  0  10.9T  0 part
sdl           8:176  0   1.8T  0 disk
`-sdl1        8:177  0   1.8T  0 part
nbd0         43:0    0     0B  0 disk
nbd1         43:32   0     0B  0 disk
nbd2         43:64   0     0B  0 disk
nbd3         43:96   0     0B  0 disk
nbd4         43:128  0     0B  0 disk
nbd5         43:160  0     0B  0 disk
nbd6         43:192  0     0B  0 disk
nbd7         43:224  0     0B  0 disk
fbsnap0     250:0    0     0B  0 disk
fbsnap1     250:1    0     0B  0 disk
fbsnap2     250:2    0     0B  0 disk
fbsnap3     250:3    0     0B  0 disk
fbsnap4     250:4    0     0B  0 disk
fbsnap5     250:5    0     0B  0 disk
fbsnap6     250:6    0     0B  0 disk
fbsnap7     250:7    0     0B  0 disk
fbdisk0     251:0    0     0B  0 disk
fbdisk1     251:1    0     0B  0 disk
fbdisk2     251:2    0     0B  0 disk
fbdisk3     251:3    0     0B  0 disk
fbdisk4     251:4    0     0B  0 disk
fbdisk5     251:5    0     0B  0 disk
fbdisk6     251:6    0     0B  0 disk
fbdisk7     251:7    0     0B  0 disk
nvme1n1     259:0    0   1.8T  0 disk
|-nvme1n1p1 259:1    0 517.7M  0 part
|-nvme1n1p2 259:2    0 517.7M  0 part
|-nvme1n1p3 259:3    0   1.8T  0 part
|-nvme1n1p4 259:4    0 526.6M  0 part
`-nvme1n1p5 259:5    0  31.5G  0 part
  `-md321     9:321  0  30.4G  0 raid1 [SWAP]
nvme0n1     259:6    0   1.8T  0 disk
|-nvme0n1p1 259:7    0 517.7M  0 part
|-nvme0n1p2 259:8    0 517.7M  0 part
|-nvme0n1p3 259:9    0   1.8T  0 part
|-nvme0n1p4 259:10   0 526.6M  0 part
`-nvme0n1p5 259:11   0  31.5G  0 part
nbd8         43:256  0     0B  0 disk
nbd9         43:288  0     0B  0 disk
nbd10        43:320  0     0B  0 disk
nbd11        43:352  0     0B  0 disk
nbd12        43:384  0     0B  0 disk
nbd13        43:416  0     0B  0 disk
nbd14        43:448  0     0B  0 disk
nbd15        43:480  0     0B  0 disk
Third, and this is even more disturbing. Yesterday I was trying to do what I needed in an Alpine container. I wanted to reboot the Alpine instance so I entered this command:
echo "b" > /proc/sysrq-trigger
THE ENTIRE NAS REBOOTED!
This is scary. This means if some bad actor gets access to a Linux container, they can mess with your entire system. This is not how containers are supposed to operate!
Am I completely off here?
But that is LXC, not docker we are talking about..right ?
No. LXC was where I tried to install CentOS but I can’t figure out the login.
Both Alpine and Ubuntu were Docker and both exposed the entire NAS filesystem.
What priviledge did you give them?
You can mount all sorts of resources for a container if you set them in the compose
I didn’t set anything in compose. I used the “Deploy” feature for that container in Container Station. I set privileged mode to on because I needed root access. I had not done that originally in Alpine and couldn’t execute root commands.
Basically I am trying to do a test with Mikrotik’s RouterOS running in a Container. I need to replace the Linux OS with RouterOS. I’ve done this in a remote VPS but want to test some things locally.
Wonder if that container uses bind mounts by default then
That’s what it looks like. Unfortunately, when using QNAP’s default “Deploy” options, you can’t edit or get access to the YAML. They should really make people aware of this.
It freaked me out yesterday when I thought I was rebooting my Alpine instance and I rebooted the entire NAS. I was scared I had also overwritten the Linux system on the NAS at that point too. Fortunately, that did not happen.
I supposed I could try setting up a Container using Compose. For a Linux install, I was concerned this would be too complicated which is why I just chose to “deploy” instead.
I will forward this issue to our internal team for further analysis. Thank you for your report!
cant you install the routerOS as a VM in virtual station? you should be able to download the iso here
https://download.mikrotik.com/routeros/7.20.7/mikrotik-7.20.7.iso
unless you specifically need to run it as a docker?
I didn’t even think about installing it as an actual VM. I did not realize that was possible. I’ve been trying to create something “Linux” and then install RouterOS. I found some Docker packages, but they are all behaving kinda weird. I have one running but it’s adding some sort of additional NAT that I can’t control and is making things work strange.
I think I’ll try your idea…
OK. Thank you again! This was perfect. I was able to do exactly the tests that I needed.
awesome glad it worked out
After internal verification, we have confirmed that this situation is caused by enabling Privileged Mode, and as such, it is considered expected behavior.
Our team will continue to improve the descriptions and instructions regarding Privileged Mode to provide better clarity in the future. Thank you for your feedback!
So here’s the issue with the way you guys do this:
1.) You may want to have root access to a linux container w/o exposing the entire QNAP drive and storage space to the container.
2.) Sending the command I did to reboot the container should NEVER reboot the NAS.
The whole purpose of running anything in a container is to keep it isolated from the main system. Having it the way it is now is a huge security risk.
