Disable Camera Audio
How can I disable audio on cameras? I don’t want live view or recordings to capture audio and I don’t see a way to disable audio in Surveillance Station.
Also, is there a way to mute audio from the Android app if camera audio is enabled? Clicking on an audio enabled camera in the app (live view or playback) plays the audio with no way to mute it other than turning media audio off on my phone. There should be a mute button within the app.
Hi @Matthew949 you can uncheck the “Enable audio recording” from Camera Settings → Camera Configuration → Video Settings
