Firmware tr-004
ITA:
Ho acquistato 2 NAS QNAP, uno da 2 dischi il TR-002 ed uno da 4 dischi il TR-004, il primo con firmware 1.3.0 il secondo con firmware 1.2.0. Ho appurato con perplessità che il TR-002 legge i dischi SSD mentre il TR-004 non li legge. E’ possibile rimediare aggiornando il firmware del TR-004?
ENG:
I purchased 2 QNAP NAS, one with 2 disks the TR-002 and one with 4 disks the TR-004, the first with firmware 1.3.0 and the second with firmware 1.2.0. I was perplexed to discover that the TR-002 reads SSD disks while the TR-004 does not. Is it possible to fix this by updating the TR-004 firmware?
the TR-004 does support SSD
so not sure what your issue is. I suggest you contact QNAP by submitting a ticket
Those ones are DAS not NAS. Have you tried to update the firmware on one ?
