I bought the TS 410 a long time ago. At the time, I used three 2TB drives in RAID 5 to initialize the system. One of the hard drives reported a failure light. After removing it, the red light kept flashing and it still couldn’t boot into the system.
Does anyone have any suggestions on how to fix this?
Removing a drive this way is a bad idea to begin with. Install the defective old drive. Does the NAS boot up again?
If so, remove the drive while the system is running and insert a new, empty drive in its place.
If not, contact support.
What does this actually mean? The system doesn’t have any indication of life? The GUI doesn’t come up? The NAS doesn’t get an IP address? You can’t access existing shares?
Translated the Chinese post to English.
If OP is not able to post in English, I will move the topic to the Chinese section.
Thanks your advice.
First, i already move bad disk.It still cannot in to system.
Second, i will buy a new disk try to rebuild data.
Last ,i will get all disk to Pc with raid to runing the. Find by Google, it said raid is base on Linux and Lvm. mybe i try to rebuild it by raid on PC .
For this matter`s risk ,i need buy anothe two disk data copy to new disk. try to rebuild in PC raid.
In that situation , qnap admin system cannot work in 2 disk raid.
It sad.
so i need find buy a new disk try to rebuild data by mechine or try copy origin disk data to new disk.
Mybe machine can work, But I dont know.
Last, If machine still cannot run admin system, i need buy new 2 disk copy origin data to new,And try rebuild data in PC raid work. Becase try to rebuild data in Pc raid have some risk,i need new disk to rebuild.
Thanks for admin, Can u touch Qnap taiwan techneican for support this problem?
You can open a ticket yourself
https://www.qnap.com/en/how-to/faq/article/how-do-i-open-a-technical-support-ticket-with-qnap
