Hi - I have followed the instructions to set up NORD VPN in QVPN. There are videos that give full details for WireGuard set up - but not enough details for setting up OpenVPN. I have toggled ‘ON’ the VPN connection profile for the NORDVPN. However, I am still not able to access the files on NAS from my laptop when I am on internet & NORD VPN turned on. I can see that the NORD VPN server that we use for setting up VPN on NAS is different to the one that we sign on when triggering the VPN in laptop. Is that the reason why I cannot access the files? If so how to resolve this issue? Just like webinar video on WireGuard, I wish there was an entire end to end setup for OpenVPN well. I am just a basic user, and hence I am requesting help
You do not need a paid VPN provider for that. (different usage)
What protocol do you want to use ?
Correct. NORD VPN is for giving you more anonymity and privacy to connect to the internet. It does nothing to allow you to connect back to your NAS. What you need to do is create your own private VPN preferably using your router. If that is not possible, then I would recommend running TailScale on your NAS and setting things up that way.
