How Max Storage pool QTS & Quts Hero
Hello everyone,
May I ask if anyone knows the maximum capacity for a single storage pool on QNAP — both on QTS and QuTS hero?
I’m still a bit confused about this and would really appreciate your help or clarification on the matter.
Thank you in advance!
Maximum capacity will depend on the particular NAS model used, and the installed RAM. Which model interests you?
I’m currently using a QNAP TS-h3087XU-RP-E2378-64G.
May I ask if this model is still limited to 308TB when using the QTS operating system?
Hi @Pikpik47 according to QNAP’s official documentation, the maximum capacity of a single Storage Pool on QTS is 308 TB.
The TS-h3087XU-RP product page also confirms that when running in QTS mode, its Maximum Pool Size is listed as 308 TB.
That’s correct — the QTS operating system is limited to a maximum of 308 TB, while QuTS hero supports up to 5 PB.
Thank you very much for confirming this. I truly appreciate your assistance, and I wish you good health always.
