How to create a container?
I had a TS453A for a long time now it had a squeeze box server in a container for many years.
Bottom line there are no containers now I wish to create a
Lyrion music Center 9.02 container now but every time it fails to create it.
Can some kind person give me simple step by step guide to do this?
Thank you!
it exist already, search lmscommunity/lyrionmusicserver in container station.
https://hub.docker.com/r/lmscommunity/lyrionmusicserver
https://lyrion.org/getting-started/beginners-guide-qnap-docker/
Hi I have been trying to create an app for this, the example worked, but has wrong ip address. I tried to load the app locally , validates ok, but does not work?
Surely this should work?
Sorry fo being trouble here, but this is frustrating!
Thanks for the quick reply.
How does your YAML look like
Lmscommity/lyrionmusicserver. Works
E:/lyrionmusicserver-9.0.2-win63.exe. Does not work
You cannot install *.exe files on container station, where does that come into play ?
How do I install a local file then?
Not sure what you mean, you create a container application via YAML, done.
No local file is needed
