How to do 2 volumes secured and not
Hello, i have a TS253A with 2 ssd (1 500go and 1 to).
I want a secured volume for work document(need 200go) 200go with both ssd on raid 1
Then I want a multimedia volume not need to be rescue on a second ssd (300 + 500 = 800go)(for musik or movies)
What is the best way to do that please? thx a lot
Can’t be done, if you RAID them together, the overage capacity on the larger disk is not usable
Thx a lot
