Improvement Suggestion: Resizable Window for "Edit Shared Folder Permission"
Improvement Suggestion: Resizable Window for the “Edit Shared Folder Permission” window
When editing file and folder permissions, one significant usability issue is that the window used for managing permissions cannot be resized or maximized.
As a result, especially when working with larger folder structures, neither the folder lists nor the corresponding permissions can be viewed in their entirety. This requires unnecessary scrolling and makes permission management considerably more difficult and confusing.
Suggested improvement:
The window for managing file and folder permissions should be freely resizable. Ideally, it should also include a maximize option, allowing users to make full use of the available screen space when needed.
This would be a relatively simple user interface improvement that could significantly enhance usability, clarity, and efficiency when managing permissions.
Also in general, different other windows could be enhanced this way, though not all of them have such a great impact on usability as this one has.
It would be great, if this tiny and seemingly simple adjustment could find its way into the firmware very quickly.
Thanks a lot for your work.
:right_arrow: My actual system is a TS-673A with QuTS hero h6.0.2.3591
