Recently purchased the TS-873A-SW5T 8 Bay NAS and installed 5 Ironwolf 8TB drives from my Synology 1515+ that has failed.
Initially, everything seemed to go smoothly with the setup; I upgraded the firmware upon startup. Once that was complete, I accessed the GUI. The unit then prompted me for another firmware upgrade, so I initiated it, but after a reset, it was still running the old version and put me on the Smart Setup again. I am now on the latest firmware, and I could access the GUI. I started creating a Storage Pool with RAID 5 using my drives, allocating 10% for reserve, aiming for around 26 TB of storage.
Since then, the GUI has logged me out, and I cannot log back in; it says my credentials are incorrect or that the account is invalid. I performed the 3-second reset, and the status light has been flashing red and green for the last 30 minutes.
I can see the NAS through Qfinder, but I cannot log in from there, and I am no longer able to access the device via browser.
I am uncertain about what is happening and would appreciate some advice.
EDIT: if I try and log in from Qfinder I get an error with “Login failed. There was no response from the server.”
