is Micron MTFDKCC3T8TFR-1BC1ZABYYR compatible with QNAP TS-h1090FU ?
I’m new to U.2 / U.3 NVMe SSD.
My customer need disks that compatible with QNAP TS-h1090FU,
I found that Micron MTFDKCC3T8TFR-1BC1ZABYY is compatible with QNAP TS-h1090FU.
Product from Micron that is available in my country is Micron MTFDKCC3T8TFR-1BC1ZABYYR (there is addition an R letter behind the product number listed in the compatibility list).
In the compatibility list under Micron MTFDKCC3T8TFR-1BC1ZABYY, there is text “As suggested by certain hard disk drive providers, the hard disk drives of the same brand and series are collectively recognized as compatible with QNAP products if the same family drive has passed the compatibility test.”
My question is Micron MTFDKCC3T8TFR-1BC1ZABYYR compatible with QNAP TS-h1090FU ?
The answer is probably. The R probably means revision. That model has probably not specifically been tested. If you have time, I think you can send drives to QNAP for testing.
