Is my TS-251 toast? (Drive-compatible replacement?)
My venerable QNAP TS-251-4G (from 2015) seems to have given up the ghost. I just want to double-check with the wisdom of the community whether that is the case, and if so what to do next (e.g. suitable replacement chassis that will take my two 3TB WD Red SATA drives with existing mostly home video/photo content).
But getting back to the symptom(s) - I tried a few things, for better or worse:
  • Was working fine, until I shut it down to relocate it, and on switching back on, the status lights were lit up l like a Christmas tree (forget exactly which LEDs, although at least one of the HDD LEDs was red), and couldn’t connect to it.
  • I tried connecting monitor (via HDMI) plus USB keyboard + mouse, and rebooting (via holding in power button till it shut down). But monitor remains black… not even a BIOS screen… and no beeps (on shutdown or reboot).
  • I tried shutting down and removing both drives (as seemed to be suggested elsewhere) and booted: screen remained black, no beeps, only LED lit is solid blue USB (+ LAN flashes orange) (other LEDs not lit)..
  • I shutdown QNAP again, reinserted both drives, and powered-on, same black screen/no-beep, and now I’ve got HDD1 solid green, LED solid blue. LAN flashes orange. (Status and HDD2 are not lit at all)
So, is my TS-251 toast? Or is there something else worth trying (that doesn’t involve a soldering iron)?
If it is toast, are there new replacement boxes, that I can slide my 2 drives into and expect them to work without too much hassle? My main use is for storage, mainly as a media server (I currently use(d) Twonky to play up to 4K home videos) - and to backup to the cloud. (My drives are not in a RAID array… hopefully one mirrors the other). In terms of O/S it was running QTS - probably not bang up to date, but I applied all available updates a couple of months back - can’t check now.
All advice would be most welcome. Thanks.
Sounds like the LPC death..often asked ..often answered
https://forum.qnap.com/viewtopic.php?t=157459
https://forum.qnap.com/viewtopic.php?t=135089
Migration Path
LPC Death (a google search on that will turn up a few other links as well)
https://forum.qnap.com/viewtopic.php?t=157459&start=450
Thanks both for confirming the symptoms.
So I understand (per the migration page) that my QTS cannot migrate to NAS running QuTS hero safely. So I need a system running QTS.
Meanwhile, according to the migration tool, my TS-251 can’t migrate to TS-216G or TS-233 directly (it talks about backing up, which is not an option with my bricked TS-251). (I’m guessing this is an Intel vs ARM thing). I think that leaves the TS-264. The migration tool does say that TS-264 will work.
However, the TS-264 has a ā€œQuTS Heroā€ label next to it on the QNAP page ( Compare Products | QNAP (UK) ).
Just wanted to sanity check, before I fork out… as I read it, the TS-264 will be shipped running QTS (which suits my needs) and not QuTS hero (but that platform provides the option of switching to QuTS hero later), right? In which case it should do the trick.
Thanks again.
When I purchased my TS-264, it came with QTS. :+1:
You really can’t ā€œswitchā€ to Hero. It’s a completely new install. You’d have to backup your data, reset the NAS, install Hero, restore data. It’s a long process.
Also, if you are going to buy a new NAS, I would spend as much money as I can afford on one.
First, I would NOT run Hero on that NAS. I think you will tap it out with just a Celeron as CPU. Plus you will want lots of memory to run Hero.
Second, I thinking the future you may want more than 2 drives. I would get at least a 4 bay unit so you can end up with a RAID 5 configuration. Just mo betta for reliability.
Only you can decide how much you want to spend and what you can afford. But I’d go as big as I could if I were you.
Backups need to be done !!before!! stuff breaks or is deleted…if you ever get your data back, start doing backups, it will save you lots of tears and/or money
Thanks for the info about QTS folks. Will also look into RAID5 and 4 bay options.
dolbyman… sorry I wasn’t clearer. The reference to backups from the migration tool was as follows when I specified source of TS-251 and destination of TS-233 or TS-216G::
ā€Your source NAS does not support direct migration to the destination NAS. To move files and data to the destination NAS, please use HBS to back up and restore files and data from one QNAP NAS to another. Check the tutorial for more information.ā€
To be clear, I do have backups (I’m not that bad), just not to a second QNAP device - those two drives back-up each other for starters :smile: , but all of the data is backed up to both AWS and OneDrive clouds. But I’d just like to slide my existing drives into a new QNAP chassis without the hassle of retrieving that data. Call me lazy. (Then if I can get that going, I’ll probably need to spend some TLC on newer bigger drives, a bit later).
well..internal backups are a bad idea, as you can see in your case.
But cloud backups are a good idea for the worst case. I wonder how much the retrieval costs are, an external backup HDD might still be worth it
dolbyman - All fair points. Am considering a WD Elements USB drive or equivalent.
I did dig out an old SATA hard drive dock this morning, but I’ve changed laptop since last using it, and don’t have an eSATA port to access that dock any more (but I’ll order a new eSATA to USB-C cable). Is there any reason why I wouldn’t be able to recover data from one of the drives in this way, if the need arose? i.e. do QNAP encrypt or otherwise ā€œprotectā€ the content of the file-system to prevent simple retrieval? Thanks.
Depending how the disks were setup it’s hard to ā€˜harder’ to read the data off it
With a static volume, you might be able to get away with a Linux reader, with storage pools you probably need special paid software.
If you are considering an alternative model, you can refer to our Upgrade Guide based on your specific needs. Thanks!
Is It Time to Upgrade Your NAS? QNAP Upgrade Guide + Must-See Model Recommendations! | QNAP Blog
I had no problem just taking my old HDDs out of my dead 251+ inserting into my new 264. HDD1 into HDD1 slot, etc. After, updating QTS and other apps, I was ready to back up my data via USB to prepare for updating the 10-year old drives as well. Rebuilding the RAID from old to new HDDs one-at-a-time took a L O N G time. QNAP tech support provided all necessary instructions.
After ~8 years of continuous use, my TS-851 has also sadly fallen victim to this issue. Same symptoms as described across the thread above and in the old forum post.
I had reached out to QNAP support for help and, although the response came within a day, it was of minimal assistance. No mention of the Celeron issue. After looking into the costs for repair and shipping costs, I decided utilize that money to purchase a compatible replacement (without drives). I moved the drives in order to a new TS-464 and booted the new system. It fired up as hoped/expected. All data safely in place.
It goes to show you how important backing up your data in multiple places is. And praise to QNAP for making migration to a new unit so straight forward.
Lucky you had only 4 disks used in your 8 bay unit.
I agree. A bare TS-464 during the holiday sales was a quick and relatively inexpensive fix for what is realistically considered an aging piece of computer equipment. I’m going to try to utilize the ā€œfixā€ posted elsewhere in an attempt to resurrect the TS-851 as an experimental unit. But this has taught me that my TVS-h874x needs a bit more planning than I gave my TS-851.
