Is there a way other than screenshot to copy current online users?
I can’t just highlight and copy-paste current online users. This would be handy to cut and paste into a spreadsheet to analyze user loads at various times.
I have never used it, but check if Q-Center has user statistics
Thanks for the suggestion. I use Qcenter daily but it has the same problem. User statistics shows online users but I can’t highlight it to cut and paste.
I do not know if the following option will serve you, but I often use in those cases is the browser tool google chrome google lens, it is very versatile truth for many cases, you just have to click the browser’s address bar when you want to use it and the option appears, then you click it, select the text you need and give it copy, work as an OCR tool even has more interesting functions.
I will try that, but it would be nice to have a solution that works in all browsers.
