Hi all,
I have a TS-233 and for years I’ve been backing it up against a standard rsync server using a custom shell script. That script exports RSYNC_CONNECT_PROG environment variable in order to create an SSH tunnel. I’ve been using rsync command from HBS 3 package.
After upgrading HBS 3 to version 26.2.0.938 my scripts stopped working. It looks like RSYNC_CONNECT_PROG is not used to establish an ssh connection before starting rsync process or it is not piped correctly.
I installed previous version of HBS 3 - 26.1.2.827 and it works just fine.
QTS firmware version is 26.1.2.827.
Was support for RSYNC_CONNECT_PROG dropped in HBS 3 version 26.2.0.938 or is it somehow broken?
Regards,
Stoyan
