Can't access my NAS anymore
Hello Becker2020,
First of all, thank you so much for your support and your patience!!!
As I already mentioned… I’m not afraid of technology and I’m patient, but when it comes to NAS I’m really just a layman and a simple home user.
So I don’t know what SSH is and would need some guidance with that.
I think I can initiate a restart via Qmanager. Is there a risk of making things worse or losing data if I do that? I made a backup to an external drive last year. Accessing this backup would be the worst-case scenario, which I obviously want to avoid.
I’ve now created a support ticket. Let’s see what happens.
By the way… I only live a few kilometers from the QNAP site in Willich. Would it make sense to bring the device there? I also asked support about that.
Then it’s not active either.
Here’s some info from QNAP:
https://www.qnap.com/de-de/how-to/faq/article/wie-greife-ich-mit-ssh-auf-mein-qnap-nas-zu
It looks like this:
For example, you can use “top” to view the running processes and do a lot more:
Back to the current problem:
Usually, you can’t make things worse by rebooting. The only exception might be a hard drive failure in a RAID (1, 5, 6, …).
But your hard drives look fine.
For now, you should wait for support.
If you need to transport the NAS to a support center, you should clarify that with support beforehand. That would probably be a special case.
So I tried to set up an SSH connection using Qfinder first. Honestly, it was a bit strange. A small window pops up where SSH connection is checked. As long as it was checked, I couldn’t click “apply.” So I unchecked it and then clicked apply—nothing happened. Then I checked it again and suddenly was able to click apply, but then I got the attached error message.
Next, I tried Putty.
I’m not sure if I might have entered something wrong, but at first I got the error message shown in the second screenshot.
Is it correct that the password entry isn’t visible in the input field?
On the second attempt, I got the message from the first screenshot. However, I haven’t seen the selection menu you showed anywhere. Maybe it’s a user error…
Yes
I think your NAS config is pretty messed up, it’s best to wait for QNAP support.
Hi everyone,
With the knowledgeable and friendly help of Mr. Zacharewicz from QNAP Support, I was able to solve the problem.
Solution: 3-second reset …then log in with the admin account and Cloud Key
Then I changed the Cloud Key password and everything is working fine.
Once again, a huge thank you to everyone for your help!!
Gotojojo
I hope the data on the NAS will always be properly backed up from now on, too. Backups are always important.
Thanks…you learn something new every day. Backups are important. And I’ll go one step further… “regular” backups are important :wink:!!
