Multimedia Console indexing PhotoPrism’s own thumbnails → endless re-index loop, count never drops, load pinned
Setup
  • TS-253B, 8Gb, QTS 5.2.6.3229
  • Single Port Network
  • Drives (RAID 2):
    • WD80EFAX-68KNBN0
    • WD80EFAX-68LHPN0
  • ~421k actual original media files on disk, ~2.5M photos in Multimedia Console
  • PhotoPrism running in Container Station — it generates and stores its own thumbnail cache
  • QNAP Multimedia Console (media indexer + myconvertserver thumbnail/transcode daemon) + QuMagie (which depends on the Console’s index/thumbnails and adds its own face-recognition AI)
Symptom
After every restart the Multimedia Console starts indexing and never finishes. The image count in QuMagie does not fall — it stays huge and keeps churning. myconvertserver and the media scanner sit at high CPU indefinitely. System load climbs past ~8, to the point where sshd starts refusing new connections.
What I think is happening
The Multimedia Console is indexing the thumbnail/cache files that PhotoPrism generates as if they were new media. Every PhotoPrism thumbnail becomes another “photo” for the Console to index and generate its own thumbnail for — which lands in a folder PhotoPrism/Console then sees again. The result is a self-feeding loop that never converges.
The smoking gun: my media DB holds ~2.5M entries but there are only ~421k actual original files on disk. The ~2M difference lines up with PhotoPrism’s generated cache/thumbnail files being swept into the Console index.
(Context: in a previous session I relocated the Multimedia Console thumbnail cache to a different location, which may have made the Console re-scan and compounded this.)
What I’ve observed / tried
  • Restarting the Multimedia Console / QuMagie — indexing just resumes, count doesn’t drop.
  • Confirmed two thumbnailing engines running in parallel (Console myconvertserver + PhotoPrism), plus two face-recognition passes (QuMagie AI + PhotoPrism) competing for CPU.
  • set AddAllShareFolder to 0 in /etc/config/medialibrary.conf
Questions for the community
  1. What’s the correct way to exclude a folder (PhotoPrism’s storage/cache path) from the Multimedia Console / Media Library scan so it stops indexing generated thumbnails? Is there a supported per-share or per-path exclusion?
  2. Given the DB already has ~2M bogus entries, what’s the safe way to purge missing/invalid entries and re-baseline the media index without a full 2.5M re-scan?
  3. Is relocating the Console thumbnail cache supported, and if so how do I point it back cleanly so it doesn’t trigger a full regenerate?
Goal: get the Console to index only the ~421k real originals, ignore PhotoPrism’s cache entirely, and let the scan complete once.
Thanks — happy to share config, myconvertserver process details, and log excerpts.
I think there was an issue with Multimedia Console. There are some other threads on here where users have indicated the indexing never stops. I believe QNAP has issues an update that fixes this.
I would say you likely want to update QTS first. Update to 5.2.9.3499. Update to the latest Multimedia Console.
Thanks for the advice @NA9D
That didn’t really miraculously help.
I have updated Multimedia console, Docker storage engine, and removed all the photoprism thumbnails altogether. Otherwise the count of the images being processed in QuMagie was not going down.
Now I just restarted reindexing of all the library, and seems like it has kicked off thumbnail generation for QuMagie too.
So after the update, is this issue still occurring? Thanks!
The original issue disappeared after I have deleted the thumbnails in question.
Now I need to wait for the qumagie thumbs rebuild, to see if adding stuff to Container station share triggers it again.
I’ll report back if I have something.
Hi @beshur the team has confirmed that the Multimedia Console was indexing PhotoPrism’s storage/cache as originals. You can change PhotoPrism’s storage out of the scan by making that folder hidden. The Multimedia Console Console does not index folders whose name starts with a dot.
The PhotoPrism recommends this too, don’t place storage inside originals unless the name starts with “.”
  • Point PHOTOPRISM_STORAGE_PATH to a hidden path like .photoprism-storage and move existing storage there (config/sidecar/backup moved, not deleted; cache regenerates).
  • Leave originals as-is — that’s what QuMagie should index.
Once hidden, new files in the Container Station share won’t restart the loop.
