"Operation not permitted" when accessing a NFS mounted directory inside a docker container
I am working on a Web-App which needs access to a QNAP-NAS file system to edit and create directories and files inside it.
In order to mount the NFS to the docker container, I used the following docker compose file:
services:
  app:
    ... # Irrelevant stuff
    volumes:
      - .:/app
      - "nfs-base:/Z" # Mount the nfs volume to the /base directory in the container
volumes:
  nfs-base:
    driver: local
    driver_opts:
      type: nfs
      o: "nfsvers=4,addr=IPADDRESS_OF_THE_QNAP-NAS,rw"
      device: ":/"
I get no error when creating the volume, and inspecting the container, the :/Z/base directory gets created, which means the shared folder base of the qnap-filesystem is propperly mounted, or at least recognised by the docker-compose file.
The problem comes when I inspect the container content to review if the files inside :/Z/base are properly mounted.
When I access the /base directory inside the container, I get the error: bash: cd: base/base: Operation not permitted.
I would like to add that when I check the permission of the folder inside the container, I get this prompt:
drwxrwxrwx 28 1000 root 4096 May 10 09:04 base
I guess it’s an issue that comes from permissions to access to the shared folder, but as I am new to the QNAP, i don’t know how to give that permissions.
Note that if I access the QNAP-NAS /base directory from the same host where I have the docker container via ssh, I have no problems with permissions ( I can access all the files in the base directory).
How can I give permissions to the docker container to read/write to a NFS mounted directory?
Since your NAS is accessible normally, the issue may not be on the NAS side. That said, based on your question, I’ll have our team take a look at your situation to see if there’s anything we can analyze or assist with. Thanks for reaching out!
I’m not sure if it will do anything but have you taken a look at the NFS sharing settings in the shared folder settings section of the control panel?
You may want to make sure your sharing settings allow unfettered access to the volume. Now, this may or may not make a difference with the container, but it’s worth a shot.
Our team would like you to verify that your NFS permissions are properly configured, including:
  • NFS is enabled for the folder
  • The IP / Subnet is allowed to connect
  • Read / Read Write permissions are enabled
  • Also, try selecting “Squash no user”
Additionally, could you test whether modifying your YAML as follows works?
services:
  app:
    volumes:
      - nfs-base:/base
volumes:
  nfs-base:
    driver: local
    driver_opts:
      type: nfs
      o: "addr=IPADDRESS_OF_THE_QNAP-NAS,nfsvers=4,rw"
      device: ":/base"
Thanks!
