Preparing NAS for AI agent work
Hi all
I would like to start a project with my son.
We want to install a local AI agent on our Qnap 873AeU-4G-EU running latest QTS 5.2.11.3661, AMD Ryzen V1500B quad CPU 2,2GHz and 64GB RAM memory.
First we want to upgrade our GPU from Nvidia Quadro P620 GP107GL 2GB used in QTS mode.
Q: Is the Nvidia RTX 2000e ADA 16GB 50W compatible with QTS? This card looks like our best upgrade for our NAS.
Secondly, we want to install a smart UPS, preferably Unifi 2U Pro, to protect our investment, as the Qnap PSU will get more loaded with a more powerful video card. We still have to figure out if there is an option where NAS is doing a controlled power down when the UPS is close to depletion. I have 3 different types of drives inside NAS and I am not planning to increase the number for time being.
Q: Any other UPS recommendations to do perform controlled shut down?
Appreciate you consideration.
QNAP only supports power down after “x” minutes of runtime since powerloss, not runtime remaining.
What Aai projects are you looking for? You might be better off with a dedicated device.
Oh and the NAS is hopefully backed up
First I want a project together :slight_smile:
Then, it will be an achievement to have a local assistent to deal with my taxes.
Nothing advanced, I guess.
A device with more space for a larger GPU can still be a project together.
No answer regarding backup
Oh and for recommendations on UPS systems, a geographical location should be supplied
You must look on the bigger picture.
A more powerful machine will generally be required, however for this use case it is sufficient. I already have them, so this will make the initial investment even more worthwhile than originally anticipated.
Any idea about compatibility?
I am living in Germany
FYI - The V1500B is not suitable, IMO, for systems doing heavy AI work. Yes, a GPU helps, but the V1500B is not a super powerful CPU, I would go with a system that is at least an i7 or i9 plus a GPU. Your call though and have fun with the project.
@Becker2020 or @manni_das_mammut might have better ideas in terms of UPS models.
No backups then..gotcha (that’s what ignoring backup questions usually means)
Keine Tränen wenn die Daten weg sind. (no tears when the files are gone)
I do have a desktop powered by latest Nvidia GPU which will be used on demand by the agent.
What I do need now is, whether the low profile, single board Nvidia card will be fully compatible with my QTS for serving cointainers.
Anyone?
If the card fits then the drivers should support it, blackwell was/is(?) an issue
Thank you @dolbyman for the comment.
I have already find out, one community member used the card on a QuTS OS. In the worst-case scenario I can switch to QuTS.
Although I was hoping a member might have this experience already.
for my TVS-h674 i use a APC CS 650.
For my other NAS i have some APC CS 500
