PSA: 35% less power consumption with TrueNAS Scale on TS-870 Pro vs QTS!
TL;DL - Faster, and 35% lower power consumption!!!
I recently bit the bullet and installed TrueNAS Scale on my TS-870 Pro (with RAM and CPU upgrades). The pros are amazing, the cons are minor annoyances and are something I can deal with. A fresh backup up 22GB of data took days! (EDIT: 22TB! Well spotted @dolbyman!)
But look at this power consumption! I didn’t screenshot usage pre-August 2025, but:
OS Power Consumption
QTS ~3.7 kWh/day
TrueNAS ~2.4 kWh/day
That’s a 35% Power saving on Daily use with the same workload of containers running.
(If imgur works, these are screenshots from a TAPO energy monitor for TS-870 Pro)
August 2025 Power Consumption:
September 2025 Power Consumption:
Pros of TrueNAS:
  • FAST to reboot. Reboot in little over a minute.
  • More up-to-date docker support since V24.04 (with caveats)
  • Snappier performance for containers
  • Containers immensely more stable. Up for months, not days.
  • 35% less Power consumption! (can’t repeat this enough!)
Cons:
  • Need to backup and delete the entire QNAP Raid Array, then rebuild in TrueNAS and restore backup.
  • Need to enable developer mode for apt-get to work
  • System changes overwritten with firmware update.Workaround for me is to script what I need installed and use brew which survives updates
  • Cannot boot from NVME drive mounted on QM2-2P10G1T card. Workaround using CLOVER on USB Thumbdrive. Looking into installing to QNAP DOM
  • QM2-2P10G1T’s 10GbE port not recognised due to lack of driver. Not an issue at the moment because my only other machine that supports 10GbE is out of commission at the moment.
That should not take that long, unless you mean TB
Haha, well spotted. Yes, I meant TB. :sweat_smile:
What version of QTS were you using? My QTS just halved the idle CPU usage after upgrading to QTS 5.2.7
QTS 4.3.6.1965 was the last version for my model, which reached end of life a few years ago.
Oh then I think it’s definitely worth switching to TrueNAS. QTS 4.3 was old and slow, with many old packages with a lot of unfixed security vulnerabilities.
What about stability and performances during heavy load and scrub/resilver?
I read that TS870 has a crappy Marvell controller for bays 3~8 and it’s not the best for ZFS especially during resilver. Any issue?
Since all people suggest using HBAs or at very least the ASM1166, I was wondering if the Marvell keeps up without problem (at least with spinning rust, not SSDs).
Please let us know!
