My Environment
NAS: QNAP TS453
QTS: 5.2.9.3499
QVPN Service: 3.3.1552
VPN Protocol: QBelt
Android QVPN Client: 1.8.11.0206
Android 15
Also reproduced on Android 8
Problem description
QBelt clients connect successfully and authentication completes without errors.
The client receives a valid VPN address from the configured pool (10.6.0.2), but no traffic passes through the VPN tunnel.
Symptoms include:
Unable to reach the NAS by its LAN IP address.
Unable to reach any other LAN device.
Unable to reach the Internet.
DNS lookups fail because no IP connectivity exists.
The QVPN client nevertheless reports “Connected successfully”.
The problem is identical on two different Android devices and Android versions.
Investigation performed
The following was verified on the NAS:
QBelt interface exists
qtun
10.6.0.1/24
UP
Client receives correct address
10.6.0.2
Routing table
The routing table correctly contains:
10.6.0.0/24 dev qtun
default via 192.168.1.1 dev eth0
Therefore:
Tunnel creation works.
Authentication works.
Address assignment works.
Routing exists.
iptables
The FORWARD chain contains no rules involving qtun.
More importantly:
iptables -t nat -L
shows:
Chain VPNNAT (1 references)
but no rules at all inside the chain.
Temporary workaround
Executing the following command immediately restores full VPN functionality:
iptables -t nat -A VPNNAT -s 10.6.0.0/24 -o eth0 -j MASQUERADE
Immediately after adding this rule:
LAN access works.
Internet access works.
DNS works.
QBelt operates normally.
This strongly suggests that QVPN Service fails to populate the VPNNAT chain automatically.
Expected behaviour
When QBelt starts, QVPN Service should automatically install the required NAT/MASQUERADE rule(s) for the configured VPN subnet.
Actual behaviour
The VPN tunnel is established correctly, but the VPNNAT chain remains empty, preventing any traffic from leaving the VPN interface.
Questions
Is this a known issue in QVPN Service 3.3.1552?
Under what conditions does QVPN fail to populate the VPNNAT chain?
Is there an official fix or workaround?
Is this corrected in a newer release?
I would appreciate confirmation from other users whether they can inspect their systems and verify whether the VPNNAT chain is populated correctly when QBelt is enabled. On a working system, I would expect at least one MASQUERADE rule for the QBelt subnet.
