Qfile Pro Version 4.5.7 (2107) is installed on my MacBook Neo (which has mobile A18 silicon inside). Now the app says that there is new version 4.6 available. However App Store says that it is not compatible with my device. So what’s up?
Thanks for the feedback! We’ll verify this situation internally first.
Hi @ymouse91 ,
Thanks for your report — and apologies for the confusion. Here’s what happened: during internal testing, a build was briefly published by mistake, which is how you were able to download it onto your MacBook. In practice, Qfile Pro isn’t intended to be available on Mac — regardless of version, you won’t find this product listed on the App Store for mac device.
That’s because Qfile Pro is fundamentally a mobile app, designed for simple tasks like uploading photos and videos from your phone to the NAS and browsing files on the go.
For Mac and Windows PCs, QNAP’s main desktop application is Qsync , which lets you synchronize data and back up selected folders. It’s likely a better fit for desktop use, so it may be worth a look:
https://www.qnap.com/en/software/qsync#applications-installation
One thing I’m also curious about: now that you’ve got Qfile Pro running on your MacBook, how is it working for you? Is it behaving normally, and does it actually meet your needs on that device? Your experience would be genuinely useful for us.
Hi everyone,
This thread raised an interesting question — how QNAP could better serve Mac users when it comes to accessing your NAS. Qfile Pro is currently a mobile app, and we’re genuinely curious about what Mac users actually want here.
So we’ve put together a short survey (about 2 minutes), and we’d love to hear from you — whether you’re @ymouse91, someone who’s tried running Qfile Pro on a Mac, or simply a Mac user with thoughts on how you’d like to access your NAS. There are no wrong answers; we just want to understand your real needs and preferences so we can prioritize the right things.
Qfile Pro on Mac — Tell Us What You Need
Thanks for helping shape the direction — your feedback genuinely feeds into how we plan ahead.
It is obvious that if you own a NAS server, one of the primary use cases is backing up or synchronizing important data to your own storage system. However, this is not my main purpose especially when not at home.
I use Qfile Pro over the Internet primarily as a way to browse, search, and read the large collection of documents stored on my NAS server. These documents include PDF files, source code, software projects, technical manuals, user guides, and various reference materials.
My goal is not to transfer or synchronize all of this data to every device I use. Instead, I want to access the information directly on the NAS and download only the specific files that I need at a given moment.
Having already used QFile Pro extensively on my iPad and iPhone, I was delighted to discover—by chance—that the same app was available for my MacBook Neo running on Apple Silicon (A18 Pro). The transition was seamless, as the interface and functionality were immediately familiar. So far, the application has performed flawlessly and fully meets my needs.
So many iOS apps can now run on OS X as you have observed. However, IMO, I think that you may get a better experience using the QNAP web interface on your laptop. The QFile interface works fine on a phone or tablet. I think the web interface works far better on a laptop.
@SamLin and QNAP:
There’s more Mac choices than what you provided in the survey which was MacBook and iMac. There’s Mac Mini, Mac Pro, Mac Studio, etc.
If you really want to improve things for us Mac users, allow us to use Qsync with more than one Mac. Your Windows app allows this.
