QFILE Pro automatic upload from photo library
Hi everyone, I have a question about QFILE Pro. I use my NAS to back up photos from my smartphone (Android). Basically, it works, but if I create a subfolder in the gallery and move pictures there, the image file is neither in the Camera folder nor does the new folder with the picture exist. Only if I completely delete the settings and set everything up again will the new folder be backed up. Is there a way to set up Qfile so that new folders are recognized automatically, or is it simply the wrong application for this task? Thanks.
Moved to the German subforum, please make sure to use the correct language!
Hallo @tomaurer,
vielen Dank, dass Sie sich die Zeit genommen haben, das Problem so ausführlich zu beschreiben.
Wir untersuchen derzeit das von Ihnen geschilderte Verhalten beim automatischen Hochladen von Fotos mit Qfile Pro.
In der Zwischenzeit empfehlen wir Ihnen, Fotos aus neu erstellten Unterordnern manuell hochzuladen, um sicherzustellen, dass diese ebenfalls übertragen werden.
Sollten wir für die weitere Untersuchung zusätzliche Informationen benötigen, werden wir uns hier erneut bei Ihnen melden.
Vielen Dank für Ihre Geduld und Ihr Verständnis.
Thank you very much for your patience! In the current version, this limitation does indeed exist, and we will improve it in a future version.
As a temporary solution, you can check if one of the following two options works for you:
  1. All photos and videos: All photos and videos are uploaded regardless of the folder — the issue you described does not occur with this option.
  2. DCIM folder: New subfolders within DCIM are uploaded automatically. Subfolders outside of DCIM, however, do not trigger automatic upload.
It would also help us a lot if you could let us know how you would ideally like to set up automatic upload. Thank you!
(Translated with AI)
