qnap does not recognize my usb-c ethernet adapter anymore
I am using TX453A with firmware QTS5.2.9.3451 and i see that my external ugreen usb-c ethernet adapter no longer works. It worked fine before.If you need logs please let me know so i can fix this issue.
best regards
Edwin
Did it happen after a firmware upgrade ?
Sometimes 3rd party devices (not on the compatibility list) can fall victim to driver updates.
its working again after reboot, not sure what happened exactly.Hopefully it was a fluke.
Glad to hear your issue has been resolved! Please keep an eye on it, and if you have any other questions, feel free to reach out to us anytime!
Isn’t “Have you tried turning it off and then on again?” troubleshooting step 1?
:slightly_smiling_face:
