Testing multiple high-quality USB cables. All of them work perfectly with the same QNAP TR-002 when connected to other computers.
Here’s where it gets interesting:
If I connect the QNAP through an externally powered USB 3.x hub (I’ve tried three different hubs), it is immediately detected, but only operates at USB 2.0 speeds.
The same thing happens if I connect it directly to the motherboard using a USB 2.0 cable: the device is detected and works normally, but obviously at USB 2.0 speeds.
Other USB storage devices work perfectly at their expected speeds, whether connected directly to the motherboard or through the new PCIe USB controller card.
Additional information:
I’ve probably connected and disconnected this device a thousand times while troubleshooting. Only twice has it been detected and worked completely normally when connected directly via USB 3.x. The next time I plugged it in, it stopped working again.
The TR-002 has four indicator LEDs: POWER, USB, HDD1, and HDD2. When everything works correctly, all four LEDs are lit.
When the problem occurs, all LEDs light up except for the USB LED. This happens immediately after connecting the device.
Does anyone have any idea what could be causing this? Is there any way to fix it?
It’s hard to troubleshoot this. If you’ve already tried an ASMEDIA card, it can’t be the chipset. It’s probably caused by a driver—mouse, keyboard, RGB, etc.
I’ve tried to disable aura (rgb) in bios, tried to unplug the mouse and keyboard and no progress. I have one usb 2.0 port on mbo, and there is also detected with no problem, but limited speed…
Thanks for the detailed testing. Since you also tried an ASMedia ASM3142 PCIe USB controller and saw the same issue, this may not be limited to the motherboard’s native AMD/B550 USB controller.
Could you help us with three additional A/B tests?
On the same ASUS USB 3.x port, test a known-good USB 3.x external SSD and confirm whether it connects at SuperSpeed.
On the ASM3142 port, test the same known-good USB 3.x SSD and confirm whether it connects at SuperSpeed.
If possible, move the ASM3142 card to another PC and test it with the same TR-002 and USB cable.
The third test would be especially useful because it keeps the ASM3142 controller, TR-002, and cable the same while changing only the host system.
If other USB 3.x storage devices work at SuperSpeed on both the ASUS ports and ASM3142, but only the TR-002 fails, this would point more toward a specific USB 3.x interoperability/link issue rather than a general motherboard USB problem.
If possible, please also share screenshots from USB Device Tree Viewer (UsbTreeView) for the working and failing cases
