QNAP TS-230 NAS Model
Is the TS-230 model still supported? I have been experiencing difficulty accessing the web-based management center.
TS-230 is a legacy product with full OS and application updates and maintenance, is there anything we can help regarding web-based management center?
I see, thank you for the information. For the web-based management center, the issue I’m facing is that when I attempt to sign in after entering the correct login credentials it loads and then just stops on an empty blue display instead of showing the dashboard. How can I resolve that?
Could be a configuration issue. It is recommended to submit a ticket, and QNAP Support Team will assist you to reset and fix the problem, thank you.
Scenario: After logging in to QTS login page, the system would hang in the blue “loading” screen.
Ref: After login on QTS system, it keeps displaying in blue and always shows “loading” | QNAP
