QNAP TS-453 Pro - Tray interchangeability with other models.
Hi, Iโ€™m looking to upgrade from an old Readynas to a used QNAP TS-453 Pro. But the QNAP is missing a tray :unamused_face:
I think the right tray for this is the SP-TS-TRAY-BLACK, but I cant get this in Australia without paying a fortune in shipping. Does anyone know if the SP-TS-TRAY-WOLOCK will fit as I can get one cheap in Australia?
Any help will be appreciated :folded_hands:
I believe it will work fine, it should be the same standard size
Thanks, thatโ€™s what I assume also.
But I really want to know 100% it it will be ok. Can anyone else confirm with certainty?
We can confirm that this drive tray is compatible and ready for use. However, please note that this specific model does not feature a lock and key mechanism. You may want to take extra care to prevent the drives from being accidentally pulled out while in operation.
