[Applicable Models]
- TS-X51: TS-251,TS-451,TS-651,TS-851,TS-451S,TS-251+,TS-451+,TS-351,D2 Pro Rev-B,D4 Pro Rev-B
- TS-XA82: TVS-951X,TVS-951N
[Security Updates]
- Applied multiple security updates to further enhance system security.
[Enhancement]
Network & Virtual Switch
- Improved the DHCP server creation and editing process. When creating a DHCP server, you can also set reserved IP addresses. It is now also possible to create a DHCP server when the adapter is using a DHCP IP address, although we still strongly recommend using a static IP address.
- You can now directly set the DHCP IP address of a client device as a reserved IP address.
- Adapter connection statuses are now displayed in "Network > Interfaces > Thunderbolt".
Storage & Snapshot
- Updated Western Digital Device Analytics (WDDA) to version 8.70.5 for improved stability.
[Fixed Issues]
- Resolved an unusual issue where some users experienced RAID group and shared folder errors after a firmware update.
- Fixed an issue where ARM-based NAS models could not join a Windows Server 2025 domain.
- Resolved a rare issue in the kernel-mode SMB daemon that caused the NAS to stop responding for some users.
- Fixed a log message that displayed the wrong operating system.
- Addressed a UI issue in the App Center settings window when the display language was set to French.
- Fixed an issue in Control Panel where right-clicking an empty area would open a context menu with the "Create Shortcut" action.
- Improved WebDAV transfer speeds.
- Improved the login authentication mechanism on certain NAS models.
- Fixed an issue where even though the QDA-A2AR adapter was already running the latest firmware, the system would still notify users that there was a newer firmware version available.
- Fixed an issue where after restarting the NAS, the system would incorrectly indicate that port trunking groups were degraded.
- Fixed an issue for some users where after a firmware update, the DNS setting for a virtual switch might disappear and become unconfigurable.
