QTS problem
When I launch finder pro my new nas is detected but only the IP is displayed. I have a warning “device &computer may not be on the same subnet”. When I click login I can’t access QTS
What is your PCs subnet and what subnet is displayed on your NAS? You need to provide some information to get help.
Based on our past experience, this connection issue could be due to your NAS and PC being on different network segments.
Could you please provide screenshots of your computer’s IP and NAS’s IP? (If you have privacy concerns, feel free to send them to me via private message.)
Also, we suggest you ensure both your devices are on the same network segment. For instance, try connecting both devices directly with an Ethernet cable to the same router, and then use Qfinder to see if that helps.
