How do I filter by multiple tags in Qumagie using ‘and’ rather than ‘or.’
If this doesn’t exist (which I’m not sure why it wouldn’t) how can I request this as a feature? As it would immediately make the app infinitely more useful which hardly any work at all.
I thought that QuMagie currently uses “And” logic when searching by tags, but doesn’t support an “Or” function — is that correct?
For instance, I’ve tagged several photos with “Unmanned” Some of these also have the “Building” tag, while others are tagged with “Nature”.
If I start by searching for ““Unmanned”” and then add the “Building” tag, the results will show only photos that have both tags — “Unmanned” and “Buildings”
However, if I begin with the “Nature” tag instead, I’m unable to select “Building” as an additional filter, since there are no photos that have both tags.
