There is a new version
QuTS hero h5.2.11.3652 build 20261014 2026-10-20
Applicable Models
- TS-h2490FU/TS-h1090FU
- TS-h1290FX
- TDS-h2489FU/TDS-h2489FU R2
- TS-h3088XU-RP
- TVS-h1288X/TVS-h1688X
- TS-h987XU-RP/TS-h1887XU-RP/TS-h2287XU-RP/TS-h3087XU-RP
- TS-h1886XU-RP/TS-1886XU-RP/TS-h1886XU-RP R2
- TS-h686/TS-h886
- TNS-h1083X
- TS-883XU/TS-883XU-RP/TS-1283XU-RP/TS-1683XU-RP/TS-983XU/TS-983XU-RP/TS-2483XU-RP/TS-h1283XU-RP/TS-h2483XU-RP/TS-h1683XU-RP
- TS-h977XU-RP/TS-h1277XU-RP/TS-h1677XU-RP/TS-h2477XU-RP
- TS-h1277AXU-RP/TS-h1677AXU-RP/TS-h3077AFU/TS-h2477AXU-RP/TS-h1077AFU
- TVS-h1675U-RP/TVS-h1275U-RP/TVS-h875U-RP/TVS-h875U
- TVS-675
- TVS-h474/TVS-h674/TVS-h874/TVS-h874X/TVS-h674T/TVS-h874T
- TBS-h574TX
- TS-873AU/TS-873AU-RP/TS-1273AU-RP/TS-1673AU-RP/TS-873AeU/TS-873AeU-RP
- TS-h973AX/TS-473A/TS-673A/TS-873A
- TVS-672X/TVS-872X/TVS-672N/TVS-872N/TVS-472XT/TVS-672XT/TVS-872XT
- TS-1655/TS-855X
- TS-855eU/TS-855eU-RP/TS-h1655XeU-RP
- TS-253E/TS-453E
- HS-264/TBS-464/TS-364/TS-464/TS-664/TS-264/TS-464C2
- TS-466C
- TS-464U/TS-464U-RP/TS-1264U-RP/TS-464eU/TS-864eU/TS-864eU-RP
- TS-i410X/TS-410E
- TS-h765eU/TS-h665U/TS-h665U-RP/TS-h1465U-RP/TS-h1065eU/TS-h1065eU-RP
- TS-h1277AFX/TVS-h877AX/TVS-h1277AX/TVS-h1677AX
- Qu805/Qu605/Qu405/TS-h665/TS-h865
- QAI-h1290FX
- TS-h1073BXeU/TS-h1073BXeU-RP/TS-h673BXU/TS-h673BXU-RP/TS-h1473BXU-RP/TS-h1873BXU-RP
- TS-467X/TS-667X/TS-867X
- TS-h966TX
Important Notes
- If your device is currently running a version earlier than QuTS hero 5.2.9, a “downgrade” confirmation prompt may appear when you manually update QuTS hero to 5.2.10 or later. The prompt does not affect the update. You can safely proceed to complete the update. This prompt does not appear when using Live Update.
Security Updates
- Applied multiple security updates to further enhance system security.
Enhancement
- Live updates on the TR- and TL-series JBOD devices now notify users of important updates, not necessarily the latest updates.
Fixed Issues
- Fixed several issues to improve system stability.
- Fixed an issue where the read speeds of a file would decrease after cloning the file.
- Fixed an issue where installing ECC memory on the TS-867X would cause QuTS hero to identify the device as TS-EC867X and thus invalidate the QuTS hero license.
- Fixed an issue where Storage & Snapshots could not identify the firmware version of a connected TL-R1200PES-RP JBOD expansion enclosure.
- Fixed an issue to improve the stability of storage pool expansion.
- Fixed an issue where taking an application-consistent snapshot of an iSCSI LUN from the NAS left the Windows VSS writers (including the Hyper-V writer) in a failed state that blocked later backups until the services were manually restarted.
- Fixed an issue where Notification Center would not send a notification when a Qfiling rule was triggered.
- Fixed an issue where running a SnapSync job from Snapshot Agent would not delete older snapshots, resulting in snapshot accumulation.
- Fixed an issue where moving a file with a long path to Recycle Bin multiple times would cause the deletion to stay in process indefinitely.
- Fixed an issue where RAID expansion could not automatically resume after rebooting the NAS.
QuTS hero h5.2.11.3652 build 20261014 | Release Notes | QNAP
