QuTS hero h6.0 Beta Testing — How I Choose Between Qtier and SSD Cache Acceleration
On my QNAP TS‑h973AX, I only have two SSDs available:
  • 1× NVMe SSD
  • 1× 2.5" SATA SSD
Because QuTS hero h6.0 allows both Qtier and SSD Cache Acceleration, I needed to decide which SSD should go where. The key is understanding the fundamental difference:
  • SSD Cache Acceleration = real‑time performance
  • Qtier = long‑term storage efficiency
Once I separated those two concepts, the optimal assignment became obvious.
:bar_chart: Qtier vs SSD Cache — What Actually Matters
Feature / Behavior SSD Cache Acceleration Qtier (Auto‑Tiering)
Speed impact Immediate — accelerates live I/O Delayed — moves data on schedule
Best for VMs, containers, databases, random I/O Large datasets with hot/cold patterns
Write behavior Write‑back = SSD‑first writes Writes still hit HDD unless SSD tier has space
When it helps Every time cached blocks are accessed Only after tiering cycles
Real‑world behavior Huge boost in responsiveness Often idle; not useful for bursts
QNAP’s intent Real‑time acceleration Storage optimization, not instant speed
:brain: Why I Prioritize SSD Cache for Performance
SSD Cache sits directly in front of the storage pool. That means:
  • Reads hit SSD instantly
  • Writes (in write‑back mode) land on SSD first
  • Random I/O becomes dramatically faster
  • VM and container workloads feel snappy
  • Bursty traffic is absorbed smoothly
This is the only feature that improves live performance.
Qtier cannot do this.
:brain: Why Qtier Is Not a Substitute for Cache
Qtier is a background data‑migration engine. It:
  • Moves hot data to SSD based on usage analysis
  • Does not accelerate real‑time reads or writes
  • May leave SSD full, offering no benefit during bursts
  • Optimizes storage efficiency, not latency
Qtier 2.0 adds IO‑awareness, but it still isn’t a real cache.
:fire: My Optimal Assignment on the TS‑h973AX
With only one NVMe and one SATA SSD, the best configuration is:
Component Role Reason
NVMe SSD SSD Cache Acceleration Fastest device → real‑time I/O → maximum performance
2.5" SATA SSD Qtier Tiering benefits from capacity, not NVMe speed
This gives me the best of both worlds:
  • Immediate acceleration from NVMe cache
  • Long‑term efficiency from SATA‑based Qtier
:brain: What I Actually Experience With This Setup
With NVMe as SSD Cache:
  • VM boots are significantly faster
  • Random I/O feels responsive
  • Write bursts are absorbed smoothly
  • Latency is predictable and stable
With SATA SSD as Qtier:
  • Hot data gradually migrates to SSD
  • Cold data stays on HDD
  • I get better long‑term storage efficiency
:bullseye: Final Summary
For my TS‑h973AX running QuTS hero h6.0:
  • I use the NVMe SSD for SSD Cache Acceleration because it gives me real‑time performance where it matters.
  • I use the 2.5" SATA SSD for Qtier because tiering benefits more from capacity than raw speed.
This configuration maximizes both performance and efficiency with the hardware I have.
First of all, if you do use Cache acceleration, NEVER do it with a single SSD drive. If that drive fails, your data is toast.
Second Cache acceleration is not what it is cracked up to be. In most cases it causes slowdowns. Once the cache is full, then everything falls back to normal read/write speeds. Unless you are accessing a large number of small files, caching really does nothing for you.
That whole post is an AI slopfest
:rofl:
I should have known…
I’m just sharing what I’ve learned while tuning my own NAS for the best performance. I used a tool to help me summarize my findings, but the testing, decisions, and configuration work are all mine.
I posted this because I couldn’t find a clear explanation anywhere else, and I figured others might benefit from the details I gathered. Not sure why it comes across as “AI slop” — this is simply the setup that worked for me and the reasoning behind it.
I’m just sharing what I learned while tuning my NAS. Hopefully it helps someone else too.”
Just post what you want to post..no need to pad this out by an AI slop machine..makes it much harder to read and it’s prone to hallucinations
I’ve been testing different configurations to optimize storage performance on QuTS using a 10GbE connection. Here’s what I’ve observed:
  • Initially, I enabled Qtier with a medium-speed tier alongside Cache Acceleration.
    • This setup delivered excellent read performance, especially for frequently accessed data.
    • However, write performance was noticeably slower, likely due to cache handling and tier migration overhead.
  • I’ve since switched to using Qtier only, without Cache Acceleration.
    • This configuration provides more balanced read/write performance.
    • Overall system responsiveness and throughput are more consistent, especially under mixed workloads.
Based on these results, I’ve decided to continue using Qtier alone for better overall performance and stability.
I hear what you’re saying, but I think there’s a misunderstanding.
I’m not trying to “pad” anything or pass off AI output as expertise. The testing, tuning, and conclusions are all based on my own hands‑on work with my NAS. I only used a tool to help structure the write‑up so it’s clearer to read, because English isn’t my strongest writing language.
Everything I shared—the benchmarks, the behavior I observed, the differences between Qtier and Cache Acceleration, and why I chose one setup over another—comes directly from my own system. I posted it because I didn’t see this comparison explained anywhere else, and I figured others might benefit from the data points.
If the formatting style isn’t your preference, that’s fine. But the findings themselves are real, and I think they’re worth sharing for anyone experimenting with QuTS hero h6.0.
You plug this company on your signature that prides itself on technical writing
You would think that a quick summary without the help of AI padding would be in the realm of possibilities.
Again, this kind of AI slopfest does not make it look better. If I see all these double quoted emoji laden writeups, I tend to zone out immediately.
But oh well…happy new year
