I forgot to mention earlier: one of the 2.5-inch SSDs failed immediately after the incident. It may be related to the underlying issue, but I’m still validating. Adding this for completeness.
QSirch is extremely CPU intensive initially as it will index every single file on your NAS. This is not an issue but a nature of the beast. When first setting up a NAS, it is best to let everything get set up and settled down before enabling QSirch. In addition you can set folders to exclude from Qsirch’s indexing. For example, likely no need to include Container Station data or Virtual Machine drives in Qsirch.
Once Qsirch is done with the indexing, it takes minimal CPU and resource time. But it is exceptionally powerful in searching for stuff on the NAS.
Thanks for explaining that — really appreciate you sharing the details about how QSirch behaves during the initial indexing. I honestly wish I had known this earlier.
In my case, my NAS ended up running for about five days in an unreachable state, and eventually the SSD died because of bad sectors. Before that, I had a similar situation where the system was unreachable for three days until I reset and reconfigured everything again.
I just enabled Qsirch again, and the NAS immediately became unreachable. This is the same behavior I saw earlier—long periods of unresponsiveness, and in my previous case it even contributed to an SSD failing due to bad sectors after days of nonstop load.
As I said, if you have just done something significant, like a major OS update like this, it’s likely that there’s a LOT going on under the hood even if you don’t think there is. Qsirch just adds to all this until the NAS settles down.
If you want to see actual usage and see what is gumming things up, open an SSH session and run the “top” command. It will show you your CPU load, and the CPU consumption of all processes. Your CPU load is the critical number. It should be less than or equal to the number of cores/threads in your CPU. If it’s higher, then things will start to get sluggish.
Hi, we’ve tried reproducing this issue internally but haven’t been able to see the same results.
Just to clarify, Qsirch on QuTS hero 6.0.0 beta is optimized for better performance, so CPU usage might be slightly higher than previous versions. However, we haven’t encountered the specific situation you’re describing.
To help us investigate further, could you share some details about your data?
Thanks for the follow-up. I appreciate the clarification regarding Qsirch optimization in QuTS hero 6.0.0 beta.
To help with your investigation, here are the requested details:
Total size of files indexed by Qsirch via Multimedia Console: Approximately 23.13 TB, spanning two storage pools.
Photos: 893,365
Videos: 11,917
Music: 0 (indexed so far)
Please note: this only reflects the subset of files added to the Multimedia Console. My full dataset is nearly double that size, including a substantial music library that hasn’t yet been indexed.
Total capacity currently being used:
Storage Pool 1: 12.52 TB used out of 21.81 TB
Storage Pool 2: 10.61 TB used out of 14.13 TB
Let me know if you’d like system specs, CPU usage graphs, or logs to help reproduce the load profile more accurately. Happy to assist further.
My NAS became unresponsive again even without Qsirch installed. At the time of the failure, the only active process was Multimedia Console indexing photos and videos. The system eventually stopped responding completely, and I had to reset the NAS and physically remove all hard drives to restore the system.
After rebuilding, I am now allowing only photos to be indexed. Under this reduced workload, the NAS has been running stably for about two days.
