QVR Pro 2.7.1.1259 2025/07/16
[Important Notes]
- For enhanced security and performance, update to v.2.7.0, which supports OpenSSL 3.0. Please note that once updated, downgrading to the previous version (v.2.6.x. and older) will not be permitted.
[New Features]
Enjoy the new features powered by CAYIN Media Viewer.
Camera Settings :
You can now view a snapshot of the streams based on the configuration in Camera Settings to confirm that the stream configuration is functioning properly.
You can enable Autosnap to periodically take and store stream snapshots.
Picture, ??
- You can assign QVR server to analyse Motion Detection for cameras that do not support it. Go to Motion Detection in the Main Menu and select QVR as the detector.
Picture, ??
Event Rules
You can now receive email notifications with an attached snapshot for events such as Motion Detection. Go to Event Rules to add a rule and configure the Email settings to attach a snapshot when triggered.
Picture, ??
- Added support for accessing the camera IP interface through Browser Station using SeaMonkey or Google Chrome. SeaMonkey is lightweight and offers faster browsing while Google Chrome provides broader compatibility with most cameras.
Picture, ??
- Integrated PPE (Personal Protective Equipment) with VCA server by VCA Technology. You can now detect when a person enters the detection zone without a hard hat or high-visibility vest.
Picture, ??
- You can now turn off the Alert Threshold in QVR when the recording space reaches its threshold and retention starts. To do this, go to Recording Storage and disable the alert.
Picture, ??
[Camera Features Intergration]
Up to 3 Video Streams supported by Dahua: IPC-PDW5849-A180-E2-ASTE, IPC-EW5541-AS, IPC-HDW5849H-ASE-LED.
License Plate Recognition by Vivotek FD9387-EHTV-V3, Hikvision DS-2CD7A26G0.
Two-Way Audio supported by Hikvision : DS-2CD2347G2-LSU/SL.
View mode supported by Axis : M3047-P
Motion Detection : triggerred by Mobotix MxActivitySensor.
[Camera Firmware Update]
INSTAR : IN-8403 2K+, IN-9420 2K+
EtroVision : N58, EV8x8xU, EV8x8xA, N71U-C/D
Axis : M3027, M4327-P, M4308-PLE, M1075-L
ACTi : E53, D42A
Vivotek : I8116-E
[Camera Intergration]
Added the following 118 cameras to the compatibility list:
Lilin : Z3R6422X3, Z2R8122X-P
Dahua : IPC-HFW4241T-AS, IPC-HFW5842E-Z4E, IPC-HDBW2433R-ZAS, IPC-HDBW4841E-AS, IPC-HFW4441T-ZAS, IPC-HDBW5442E-ZE, IPC-HUM8441-E1, DH-SD3E410DB-GNY-A-PV1, DH-SD3E410DB-GNY-A-PV1, IPC-HFW3441T-AS-P, IPC-HDBW3441R-AS-P, IPC-EBW8842-AS, IPC-EBW5641-AS, ITC413-PW4D-Z3.
Hikvision : DS-2CD2346FWDA4, DS-2CD3T45P1, DS-2CD3346P1, DS-2CD3346WDV3, DS-2CD3546FWDV3, DS-2CD3546FWDV3, DS-2CD7147EWDV2, DS-2CD2346G2P, DS-2CD63C5G1, DS-2CD6365G1, DS-2CD2087G2H-LIU/SL, DS-2CD2T87G2H-LISU/SL, DS-2CD6D55G2-IZHS, iDS-2CD7A46G0/P-IZHSY, DS-2CD2187G2H-LISU, DS-2CD1183G2-LIU, DS-KV6113-WPE1(C).
Foscam : SD8P, SD8EP, V4EC, V5EP, V5EP-V2, V8P, R8M, PD5, SD4H.
VCA : Camera - IPAi65A05-MR , IPAi345S-FR, Server AI Bridge ABP301(8CH), ABP302(12CH)
IPOX : PX-TZI4012IR5DL/W, PX-SDIP4525G3.
Reolink : E1 Outdoor Pro E560.
Mobotix : c71, MX-MD1A-5-IR, MX-MD1A-5-IR.
TP-Link : TL-IPC443MEP, IPC48AW, VIGI C485, C345, C240, C211, C200, C125, C110, C100, C120.
SHANY : SNC-HDL987M5033MS.
Instar : IN-8403 2K+, IN-9420 2K+
HiSharp : T058SJ
Panasonic iPro : WV-S1135V, WV-X22600-V2L.
Reolink : Duo Floodlight PoE/WiFi, P830, RLC-823S1, RLC-840A, CX810, E1 Outdoor Pro, RLC-1240A.
Bosch : NDS-5704-F360LE.
Axis : M4318-PLR, M3057-PLVE MKII, I8116-E.
Vivotek : FD9387-EHTV-v2
Pelco : IMF82-1ES
Uniview : IPC3605SB-ADF16KM-I0, IPC2K24SE-ADF40KMC-WL-I0, TIC2A32SA-F10-4F8AC-I1, IPC86CEB-AF18KC-I0, IPC3224SS-ADF40K-I1, IPC2324SB-DZK-I0, IPC3624LE-ADF28K-WP-NB, IPC3514LE-ADF40K-WP.
Canon : VB-S32D, VB-S32VE, VB-H47.
Dp smart : Rogy360 Pro.
Hanwha : ANV-L7012R, ANV-L7082R, ANO-L7012R, ANO-L7082R.
[Fixed Issues]
Fixed an issue with disconnection between the system and QNAP USBCAM2 cameras when “HTTPS Only” is enabled.
Fixed an issue that caused the relaunch process to occur when setting up the Dahua DH-IPC-HFW1230A-A camera through Generic RTSP without filling in the IP address information.
Fixed an issue where the HDD health log was recorded even though the disk was not set up for recording.
Fixed an issue with the failure to send email notifications when the email account contained the symbol Plus + .
Fixed an issue with the failure to send email notifications through SMTP servers.
Fixed an issue with the failure to capture snapshots as previews from Secuplug IPD-E2A5Y04 camera.
Fixed an issue with system data not being stored in the same location where QVR Pro was installed.
Fixed an issue with the failure to play back 4K H.265 videos on some channels when multiple channels are being played back simultaneously from the QVR Client.
Fixed an issue with the failure to send emails through SMTP servers after updating to QTS 5.2.4.
Fixed an issue with failure to change GOP settings to Hikvision 2CD2012-I cameras.
[Known Issue]
- When searching for Dahua cameras IPC-HFW3441T-AS-P and IPC-EBW8842-AS, camera brand will be identified as ONVIF. If you are adding these two cameras, please identify them using either the IP address or the MAC address.
Picture, ??
[System Requirements]
- Minimum Memory: 4 GB
