I wanted to ask you about the camera recording system I have installed on my NAS.
I’m currently using QVR Pro, but I just saw in the App Center that there’s a new application, QVR Surveillance.
Right now I only have one camera (H.265 3840x2160 ~5.2 Mbps) and I want to add another similar camera in the future.
I’ve searched extensively on the QNAP website and on sites like Reddit, but I don’t understand the difference between these two applications (QVR Pro and QVR Surveillance).
I have to say I’m quite happy with QVR Pro, but if QVR Surveillance offers any advantages over QVR Pro, I’m willing to switch applications.
So QVR Surveillance will eventually replace QVR Pro. Sometime in early 2026, QNAP will release a migration tool that will allow migration of your cameras and video to QVR Surveillance. At that point, it will become the “preferred” solution.
There is really no functional difference. QVR Surveillance is possible a little less intensive on the CPU.
The biggest difference is how the video files are stored. In QVR Pro, it creates multiple shared volumes on the NAS and allocates space to those. In QVR Surveillance, the video is stored on a folder in a regular volume on the NAS. So file and space management becomes a little easier.
If you don’t care about losing your video files, you can switch now. Export your camera settings from QVR Pro to a .csv file and then import those into Surveillance. You’ll need to recreate all your event rules as well.
is there a different license fee necessary? I have two camera yet and not necessary to expand an dhave the license for QVR AI pack. And it is runnign on a normal NAS (TS-453D) Do i need to pay additional if i migrate to the serveillance version?
Hi @renevk no, the QVR Surveillance is compatible with all existing QVR Pro and QVR Elite licenses, so you can continue using your current licenses without any additional fees.
QVR Surveillance uses a different file storage method than QVR Pro, so there’s no direct upgrade path. A couple of options depending on your recordings:
If you don’t need to keep your current recordings, you can just reinstall and switch over to QVR Surveillance. It’s pretty lightweight on system resources, so it should actually run nicer on the TS-453D than QVR Pro does.
If you want to keep your old video files, please wait for the QVR Pro 2.8.0 update which we plan to release it in Q3. That version has a built-in migration tool to move your data over to QVR Surveillance.
Please let me know if you have any other questions.
While it’s not currently possible to migrate from QVR Pro to QVR Surveillance, you can export camera settings from QVR Pro and then import them into QVR Surveillance, which reduces the need for reconfiguration.
The new software works wel so i would liek to decom the old software and data. If i will deleted the old files , which files can i delete? I see that e.g. QVRProSpace_DATAVol1 contains old data. And which Share folder can i delete?
Hi @renevk yes, if you no longer need QVR Pro or its old recordings, you can uninstall QVR Pro and remove its remaining shared folders. These are the folders created by QVR Pro whose names start with “QVRPro”, including “QVRProSpace_DATAVol1”, which stores the old recordings.
Before deleting them, please check QVR Surveillance’s Recording Storage settings to confirm that none of these folders are used for your current recordings.
