QVR Recording Vault - Enterprise-grade active video backup solution
Facing increasingly severe cybersecurity challenges and regulatory requirements, QVR introduces the brand-new Recording Vault solution, offering a license-free, proactive backup option designed specifically for multi-site enterprises. Without changing your existing architecture, QVR Server recordings are automatically backed up to headquarters NAS, allowing endpoints to focus on real-time monitoring with no performance loss.
Key Features
  • High Security: Strict access control and data encryption ensure only authorized personnel can access, safeguarding sensitive information.
  • Zero License Fee: One-time deployment for lifetime use, flexible management of multi-endpoint footage, significantly reducing operational costs.
  • Proactive Backup: Seamlessly integrates with endpoint servers, automatically executing backup tasks to ensure front-end monitoring performance.
  • Flexible Settings: Customize retention days and capacity based on servers and cameras for precise backup strategy control.
  • Long-term Retention: Supports video retention from hundreds to thousands of days, easily meeting compliance and enterprise cybersecurity needs.
QVR Recording Vault integrates perfectly with the QVR ecosystem, allowing recording and backup to perform their respective roles—enhancing both stability and security while effectively managing costs. Now is the best time to build a robust, secure, and scalable surveillance architecture.
Deploy QVR Recording Vault now to achieve a robust, secure, and scalable surveillance video backup architecture, fully protecting your enterprise assets.
https://www.qnap.com/zh-tw/software/qvr-recording-vault
