QXP-W6-AX200 Replacement
Is there an officially approved replacement for the QXP-W6-AX200 wifi extension card?
Forget about internal WiFi cards, use a Wifi bridge if you HAVE to use Wifi
Thanks for reaching out! May we ask which model you are currently using? Regarding future models or products with similar features, please stay tuned to our official announcements, as updates will be made primarily through our official website. Thanks for your support!
I’m presently using the TVS-472XT.
Or just use a Wifi bridge, it’s works fine and is build into most range extenders with a LAN port, easy peasy.
